Topic "Access violation at address 0074D41F in module 'WinSCP.exe'"
Coquimba
I am using the latest WinSCP 5.0.7 beta on a Windows Server 2008 SP2 32 bit and I received the access violation at address xxxx in module 'WinSCP.exe'
I solved by changing the preference to Explorer. I did this because of another post that had the same issue on a much earlier version and suggested that as a solution.
At least I wanted to report the issue so you can keep on improving this great app.
When did this occur?
mcovey
I am also getting this error. This happens after loading the connection window, right after the last step of connecting, before it attempts to render the SFTP browsing window.
I am Running winscp 5.0.7 on Windows 7 x64, service pack 1.
I took all the steps I could think of to clean up my environment to test - closed all other running programs, tried running it as administrator, cleared out temp folder, etc.
I have .NET framework 4 Client Profile and .NET Framework 4 extended installed.
mcovey
I have sent the email. Thanks.
mcovey
After using the debug build, I find that I am able to connect without error using the beta and debug versions.
I suspect that this may be related to a network driver issue that I fixed in the meantime. I was having a problem with Dropbox freezing my computer during sync, and at the advice of someone on their support forum, I installed an older Vista driver for my motherboard's LAN card. The motherboard is ASUS P5KPL-VM and the network driver is here: Atheros L1 Ethernet driver V2.4.7.15 for Windows 2000/XP/XP 64bit/Vista 32bit/Vista 2009.02.05 update.
In case anyone has this problem, if you have an Atheros network card, look for alternative network drivers which seem to work much better.
FYI: I observed the same problem here with an Asus P5QPL-VM EPU board and Version 1.0.0.37 official stable driver from asus website after a fresh XP/SP3+ all patches install with a new not yet saved session.
Problem went away as soon as I saved the session, weird.[/url]
pee
I get this error at least daily, especially when winscp is running for several hours.
I get then one or more message boxes with this error. upgrading to the next versions does not help.
any suggestions?
thanks
any suggestions?
The same as above:
