Topic "Host key wasn't verified!"
sql101
I am using the script tool to ftp to our secure ftp site. Could you please help me to see whcih part went wrong? It is conplaining about the hostkey when running through SQL Analyer but no problem if I typed them manually in command prompt
I have a batch file sftp_test.bat with one line command
WinSCP.com /script=D:\sftp_test.txt
sftp_test.txt contains the following
option batch off
open username:pasword@site
Put d:\TestYYYYMMDD.txt
close
I have no problem running it by double clicking it or through the NY schedular but I can not run through SQL (I want to schudule as a SQL Job then with all the notification benefits)
When I run through SQL analyzier "exec master.dbo.xp_cmdshell 'D:\sftp_test.bat'"
here is the result I got
NULL
C:\Windows\system32>WinSCP.com /script=D:\Uploads\sftp_CAPSJob.txt
batch off
confirm off
Searching for host...
Connecting to host...
Authenticating...
The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
The server's rsa2 key fingerprint is:
ssh-rsa 2048 6d:c9:34:0e:8a:bb:3e:26:3a:75:9d:38:1a:13:11:0e
If you trust this host, press Yes. To connect without adding host key to the cache, press No. To abandon the connection press Cancel.
Continue connecting and add host key to the cache?
(Y)es, (N)o, C(a)ncel, (C)opy Key: Cancel
Authentication failed.
NULL
But I want to be able to use SQL agent instead of the cmd prompt or schedular
much thanks
Please read FAQ:
http://winscp.net/eng/docs/faq_scheduler
tsantony
hi,
this is antony here, did you get the answer for your question? i'm also facing the same issue.
please help me.
regards,
Antony
option batch off
close
NULL
batch off
confirm off
Authenticating...
NULL
much thanks
drfunk2458
did you try using the "/privatekey=" option ??
tsantony
yes i'm using Privatekey option
currently i'm receiving different Error
Information: 21/Jan/2013 10:16:04 Searching for host...
Information: 21/Jan/2013 10:16:04 Connecting to host...
Information: 21/Jan/2013 10:16:04 Authenticating...
Information: 21/Jan/2013 10:16:04 The server's host key was not found in the cache. You have no guarantee that the server is the computer you think it is.
Information: 21/Jan/2013 10:16:04 The server's rsa2 key fingerprint is:
Information: 21/Jan/2013 10:16:04 ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx.....
Information: 21/Jan/2013 10:16:04 Connection : open sftp://sftpmazda@xxx.xxx.xxx.xxx:xxxxx -hostKey="ssh-rsa 1024 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx....."
Error: 21/Jan/2013 10:16:06 Connection has been unexpectedly closed. Server sent command exit status 0.
Error: 21/Jan/2013 10:16:06 Authentication log (see session log for details):
Using username "sftpmazda".
Access denied.
Error: 21/Jan/2013 10:16:06 Authentication failed.
any one please help me
regards
Antony
tsantony
i'm receiving the following error.
Access denied.
please help me
regards
Antony
Please read:
http://winscp.net/eng/docs/scripting#hostkey
If that does not help, attach a full log file showing the problem (using the latest version of WinSCP).
To generate log file, use /log=path_to_log_file command-line argument. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
tsantony
thanks a lot, i fund the answer.
i have include the /privatekey and /hostkey, then i got the answer
thanks again Very Happy
regards,
Antony
prikryl wrote:
Please read:
Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
tsantony
i want to capture only "Network" related errors. may i know how i can do this?
thanks advance.
regards,
Antony.
This is not supported.
tsantony
thanks for your reply.
but i found the way to capture the Network ERRORs.
process.ExitCode <> 0
regards,
Antony
That captures any error, not only network errors.
tsantony
i'm testing my app. i'll let you know. once i have done.
samk3nny
I am seeing the same error but within Powershell.
I have set the following but keep getting the message "Host key wasn't verified!". I am assuming it is something related to the setting of my session options. If I use the ppk file and login details below through the GUI, it works fine. I also tried using a .ini file and putting that both where winscp is run from and where the Powershell script, but with no luck.
Any ideas?
Sam
# Setup session options
$sessionOptions.Protocol = [WinSCP.Protocol]::Sftp
$sessionOptions.HostName = "sftp.site.com"
$sessionOptions.UserName = "my_login"
#$sessionOptions.Password = "mypassword"
$sessionOptions.SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
$sessionOptions.SshHostKey = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
$sessionOptions.SshPrivateKeyPath = "\\Path\to\File"
$sessionOptions.SshPrivateKey = "myfile.ppk"
Please attach a complete session log file (set Session.SessionLogFile). Please note that public host key is not a secret information.
Also (not related to your problem):
SshHostKey is obsolete name of SshHostKeyFingerprint. No point setting both.
SshPrivateKey is obsolete name of SshPrivateKeyPath. No point setting both. Either should contain full path (folder path and filename).
vibs
you need to add the hostkey in the commandline
http://etlexperts.blogspot.com/2015/10/winscp-host-key-wasn-verified.html
