Topic "How to Open a Stored Session"
lee_qiao_2000@yahoo.com
Hi!
I know we can open a session using SessionOptions class. How can we open a session with stored session? Sometimes we have to use proxy, which can be specified in the GUI and stored, and this can't be added in SessionOptions.
Thanks in advance.
L
It is not supported.
You can configure any session settings, including proxy, using SessionOptions.AddRawSettings though:
http://winscp.net/eng/docs/library_sessionoptions#methods
That's good. Thank you!
Vara04
I try this and it seems to work
Protocol = Protocol.Ftp,
HostName = "TestFTPLocal",
   session.DefaultConfiguration = false;
   session.IniFilePath =@"D:\yourdir\winscp.ini";
   // Connect
   session.Open(sessionOptions);
And in "D:\yourdir\winscp.ini", I set my conf
[Sessions\TestFTPLocal]
HostName=myserver
PortNumber=21
UserName=myuser
FSProtocol=5
Password=[encryptPwd]
I copy this from winscp.ini of winscp GUI
I hope it helps you
Yes this works. I suggest you use my suggested approach anyway.
