Topic "Files regularly not written correctly by PUT"
Febo
Hello
I've built a VBA program that creates batch files to PUT single files from a windows server onto a linux web server.
The files are plain ascii CSVs of no great size.
I'm using option binary, but only because I get the same problem with option ascii.
Occassionally, the file's contents are either truncated (last line is incomplete) or actually scrambled - I'm looking at a file in which the last 10 or so lines occur TWICE at the end of the file.
When I check the source file its OK - only the uploaded file is corrupted
Any ideas?
No ideas? Gonna have to find a new product I'm afraid.
febo
Sorry, that won't help you - the log file just says the file was uploaded successfully. I've had to go for another product i'm afraid.
sorry
Febo
I thought you might be interested in this:
When I solved this problem I did 2 things:
1. I changed my ftp software (sorry!)
2. I changed a bit of VBA code that was responsible for ensuring that only 1 PUT at a time was being executed. This code I believe, was not working - it was letting the next PUT start before the last one had finished, and was probably re-trying to re-PUT the same file, hence, possibly, the resulting messup....
Because I changed both things at the same time, I don't know which one actually solved the problem.
