download of WinSCP.DLL version 4.3.7
Bispen
Denmark
I am using winscp 437 and would like also to utilise the .net assembly. However when i look at the winscp download page it appears that the .net assembly is only available for winscp 507 beta?
I have downloaded the winscp 507 dll but when I try to use it in a solution i get a warning that there is a discrepancy in versions and I am warned against overruling this discrepancy (but apparently it is possible).
Preferably I would like to get the dll for 437 is this possible?
Br
Hans Jørgen
Re: download of WinSCP.DLL version 4.3.7
The .NET assembly is available for 5.0.x only and you cannot use it with WinSCP 4.3.x, no matter if you override the version check.
