Topic "Invalid access to memory and tray icon issues"
I'm currently using WinSCP 5.07beta and I'm facing two serious problems with it:
1. Random invalid access to memory issues. In most cases this error occures when I want to close my windows and WinSCP is sitting in the tray. Sometimes this error occures when I try to connect with WinSCP to remote server (but this issue is reproducible only on my clean Windows 7 machine, which I insalled few days ago).
2. When I put WinSCP to tray I cannot bring it back. Klicking on tray icon does no effect at all. As a temporary fis I use process explorer and it's option to recover windows from tray.
I don't have issues with lates stable version of WinSCP. I use Windows 7 64-bit SP1 (Polish) on all of my computers where I use WinSCP.
My connection parameters:
Session protocol = SSH-2
SSH implementation = OpenSSH_5.9p1 Debian-5
Encryption algorithm = blowfish
Compression = ZLib
File transfer protocol = SFTP-3
Server host key fingerprint
ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx
Can change permissions = Yes
Can change owner/group = Yes
Can execute arbitrary command = No
Can create symlink/hardlink = Yes/No
Can lookup user groups = No
Additional information
The server supports these SFTP extensions:"1""2""2""1"
Thanks for your post.
This bug is being tracked already:
