Topic "peer certificate rejected exceptio"
terrence
HI,
I installed 5.0 beta Winscp and reference Winscp.dll use C# code , but I can't connect to server successful.Throw exception --> WInSCP.sessionRemoteException:peer certificate rejected .
What's problme, Who can help me
sangeethu
Even I am facing the same problem. Please let me know whether you resolved this issue.
Make sure you set SessionOptions.SslCertificate (renamed to TlsHostCertificateFingerprint is the later versions) to accept the untrusted certificate:
http://winscp.net/eng/docs/library_sessionoptions
MrRanger
What Value would you set it to in order to accept the untrusted certificate
Fingerprint of the untrusted certificate.
MasieroR
I've the same problem.
I set the SessionOptions.SslHostCertificateFingerprint with the fingerprint of the untrusted certificate, but when I try to open the session, the application freeze and I've to kill the app.
Thank you.
MasieroR
Installing the latest version (5.1) the problem does not recur.
Thank you.
Suganya
When i try to establish a connection using FTP, i am encountering the following error,
"Peer Certificate Rejected , Disconnected from server , Connection Failed"
Please start anew topic and attach a full log file showing the problem (using the latest version of WinSCP).
