Topic "Make "Remember last dir..." be a global setting?"
Pathduck
I have an INI with over 100 servers, and would prefer to not have WinSCP remember what directory I was working in last session as is default in v5.0.
I know this can be set as a default setting, but will only be on created sessions from then on. Already existing sessions have to be edited manually, or (like I do) the INI edited directly, which is a hassle Confused
Is there any way to have the option "Remember last used directory" be a global setting affecting all sessions?
Oop, maybe should be under "feature requests"...
Thanks for your suggestion. I'll consider it.
