Topic "Windows 7 firewall problem."
plaintex
I'm using automation to download entire contents of remote FTP server to my local clean install Win 7 machine.
For the connection I am using FTP with TLS Explicit in passive mode with keepalive of 30 seconds.
This is my script:
option batch on
open XXXX@X.X.X.X
option transfer binary
synchronize local C:\SITE -delete
close
Everything has been working fine for months until I installed some web apps to the FTP server with 100's of files and many folders (wordpress/gallery etc).
Now I get this error in the console 3 minutes into the synchronization:
Lost connection.
Disconnected from server
Accepted data connection
Error listing directory '/xxxx/xxxx/xxxx/xxxx/xxxx'.
Session 'XXXX@X.X.X.X' closed.
No session.
No session.
No session.
No session.
No session.
No session.
This only occurs after 3 minutes of traversing directories which did not need updating on the local machine. When run the first time, when the local directory is empty, I do not get this problem.
When I disable the Windows Firewall entirely the synchronize works. However, with the Windows Firewall turned on and no matter what settings I seem to try I always get the problem.
I am not a windows firewall expert but in testing I have tried:
1. Allowing all connections for WinSCP.exe and WinSCP.com
2. Telling the firewall to 'Allow' for all inbound connections, to any program (configured in 'Advanced Settings>Firewall Properties>Private Profile' of Windows Firewall).
3. Telling the firewall to log dropped packets (the log remains empty).
The error only seems to go away when I completely turn off the firewall ('Advanced Settings>Firewall Properties>Private Profile>Firewall State>OFF').
The firewall log does not show any dropped packets, which is confusing me.
What are the correct settings to overcome this issue?
Thank you for such a great program. Any help appreciated Smile
plaintex
I seem to have solved my problem by using SFTP instead. Very Happy
But would still love to know why windows firewall on client was causing passive FTP connection to be unreliable - I would prefer to use it.
