Topic "problem with filemask"
asdad
Hi
I'm trying to use command line winscp to copy a folder to a server, excluding svn files.
@echo off
set winscp="c:\Program Files (x86)\winscp\winscp.exe"
%winscp% mysite /console /command "option confirm off" "put -filemask=.svn %localfolder% %remotefolder% " "exit"
No matter what I set the filemask to, no files get uploaded (things work fine without the filemask, so never mind the tokens).
Ideally, I would like to exclude everything beginning with "." - I tried .* as filemask, is that right?
I also tried
%winscp% mysite  /console /command "option confirm off" "option exclude .svn" "put %localfolder% %remotefolder% " "exit"
it seems to recognize the option - console prints "confirm off, include |.svn"
So exclude turns to include and again nothing gets uploaded
Using latest version 5.0.7 (build 2268)
Correct file mask is |.svn/
%winscp% /console /command "option confirm off" "option batch on" "open mysite" "put -filemask=|.svn/ %localfolder% %remotefolder% " "exit"
asdad
Hi
Thanks for the reply
However, still doesnt seem to be working. Tried adding the filemask to both your and my version of the command, but it still ignores ALL files as soon as I do so.
Last lines of console (when I remove the exit command):
Session started.
Active session [1] xxx
winscp>
Both versions work fine without filemask.
Please post a complete batch file you use to run WinSCP.
jadiagaurang
I have same requirements. I want to ignore .svn directories from my local directory to remote directory.
Here is my deploy script. Let me know what I am missing here.
option batch abort
open ftp://%3%:%4%@%2%
put -filemask=|.svn/ %1%\*
But, It gives me error saying that Unknown switch 'filemask'.
Gaurang
GuestIV
Filemask switch only works in the version 5 beta. Use quotation marks.
Try:
Quote:
put -include="* |.svn/ %1%\*"
Not tested so it might need some changing.
If you are using 4.3.8, use
option exclude ...
or
option include ...
http://winscp.net/eng/docs/scriptcommand_option
