Topic "setting timeout problem"
IGGt
I am trying to manually set the timeout in my script, but can't get it to work.
if I type:
winscp>open username:password@address -timeout=100 -passive=on
then it connects fine, and the timeout is 100 seconds.
But If I try to put this into my script file it fails:
c:\>winscp.com /script="path/to/script.txt"
script.txt:
command1
command2
Then I get the following error: "The filename, directory name, or volume label syntax is incorrect"
I tried adding it after the /script parameter as /timeout=15 or -timeout=15, but get the same error.
Is there something I am doing wrong?
Please post a screenshot.
IGGt
I have figured it now.
I needed to change:
to
open ftp://username:password@address -timeout=100 -passive=on
and now it works,
cheers.
kiran
I could able to transmit the file with console application with same code.
but when we are trying to integrate with window service, we are getting the below error, while executing the service.
"WinSCP.SessionRemoteException: System Error. Code: 123.
Please try to help me to get resolve this issue.
Thanks In Advance,
kiran
Please, start a new thread and attach a full session log file showing the problem (using the latest version of WinSCP).
