Topic "WinSCP.SessionLocalException: WinSCP process terminated with"
cpvl
So im using the .NET assembly and i've tested this using Visual Studio debugger and then when I test it through the web server I get this error.
WinSCP.SessionLocalException: WinSCP process terminated with exit code 3 and output "", without creating a log file.
at WinSCP.Session.Open(SessionOptions sessionOptions)
at BuildSystem.Members.BuildLog.EditBuild.ScpPut(String fileUpload) in E:\BuildSystem\WebClientVersion2\Members\BuildLog\EditBuild.aspx.cs:line 59
I've pretty much used the code from the .NET Assembly example
Protocol = Protocol.Scp,
HostName = ConfigurationManager.AppSettings["RemoteHost"],
UserName = ConfigurationManager.AppSettings["FileServerUsername"],
Password = ConfigurationManager.AppSettings["FileServerPassword"],
SshPrivateKey = "C:\\privatekey.ppk",
SshHostKey = "ssh-rsa 2048 xxxxxxxxxxxxxxxxxxxx",
session.Open(sessionOptions);
// Upload files
TransferOptions transferOptions = new TransferOptions();
transferOptions.TransferMode = TransferMode.Binary;
TransferOperationResult transferResult;
transferResult = session.PutFiles(@fileUpload, ConfigurationManager.AppSettings["FileServerUploadDir"], false, transferOptions);
// Throw on any error
transferResult.Check();
// Print results
foreach (TransferEventArgs transfer in transferResult.Transfers)
Console.WriteLine("Upload of {0} succeeded", transfer.FileName);
WinSCP never returns exit code 3. So it could be system-level exist code, indicating WinSCP was never started:
http://www.hiteksoftware.com/knowledge/articles/049.htm
Where are your winscp.dll and winscp.exe located?
cpvl
They're located in the BIN folder of the .NET project which were copied from the Program Files folder after installing WinSCP and downloading .NET Assembly
cpvl
I've also used the Session.ExecutablePath property to force the assembly to look for the winscp.exe in a different location as the documentation suggested and still have the same error.
session.ExecutablePath = ConfigurationManager.AppSettings["WinSCPExePath"] + "WinSCP.exe";
cpvl
So after i restarted the server the exception went away and now i have a
Error: System.TimeoutException: Timeout waiting for WinSCP to respond.
at WinSCP.Session.CheckForTimeout()
Please set Session.DebugLogPath and Session.SessionLogPath and post or email me both logs.
