Topic "System.OverflowException in WinSCP.ConsoleCommStruct..ctor"
zarkoh
Following the C# example given at http://winscp.net/eng/docs/library#csharp
with the same standard SessionOptions configuration, I am getting the following
Error: System.OverflowException: Arithmetic operation resulted in an overflow.
at System.IntPtr.ToInt32()
at WinSCP.ConsoleCommStruct..ctor(Session session, SafeFileHandle fileMapping)
at WinSCP.ExeSessionProcess.AcquireCommStruct()
at WinSCP.ExeSessionProcess.InitializeConsole()
at WinSCP.ExeSessionProcess.Start()
at WinSCP.Session.Open(SessionOptions sessionOptions)
at ConsoleApplication1.Program.Main(String[] args) in ...\Projects\ConsoleApplication1\ConsoleApplication1\Program.cs
:line 28
on session.Open(sessionOptions);
This basic attempt was made in a console application in VS 2012, targeting .NET 4 and using the latest dll and exe of WinSCP 5.0.7 beta.
Does anything obvious come to mind?
I suppose you are using 64-bit OS, right?
https://msdn.microsoft.com/en-us/library/system.intptr.toint32.aspx
https://winscp.net/tracker/show_bug.cgi?id=869
zarkoh
Yes, using a 64-bit Windows 8 (Release Preview).
Trying on a different machine with the same OS I don't experience the issue, so it is probably some 32-bit vs. 64-bit combination of Visual Studio / solution / project target configuration that is causing the failure.
I'll report back if I manage to force it or bump into it again.
http://msdn.microsoft.com/en-us/library/system.intptr.toint32.aspx
http://winscp.net/tracker/show_bug.cgi?id=869
