Topic "WinSCP does not connect...."
Heinz Lindemann
Hi all,
about 6 months ago I tried winscp for a "one-time" experience. I downloaded the software, installed, provided the login data...
WOW, it worked, I could reach out to another server and push data there.... I was impressed!
However, at that point in time I thought I won't use anymore and uninstalled. What a mistake!
Today, I feel my previous decision was wrong and have re-installed version 4.3.8.Same PC (w7, sp1), same target PC, same login data...
But this time it doesn't work at all (timeout error). Friends told me I should check the windows firewall. It was on and it was switched off then on purpose. It is still not working.
BTW, I can ping the target server, it is online!!!
Any idea?
Regards, HL
Heinz Lindemann
Hi community,
any help is appreciated...
Regards, HL
Are you sure you are using the same protocol?
Please post a log file.
Heinz Lindemann
Hi Martin,
I assume yes, because I just installed the software and used it "as is".
Here comes the log (some areas crossed out...), I hope it helps....
. 2012-06-20 03:23:32.293 --------------------------------------------------------------------------
. 2012-06-20 03:23:32.293 WinSCP Version 4.3.8 (Build 1771) (OS 6.1.7601 Service Pack 1)
. 2012-06-20 03:23:32.293 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2012-06-20 03:23:32.293 Local account: xxx\yyy
. 2012-06-20 03:23:32.309 Login time: Mittwoch, 20. Juni 2012 03:23:32
. 2012-06-20 03:23:32.309 --------------------------------------------------------------------------
. 2012-06-20 03:23:32.309 Session name: xxx@yyy.dyndns.org (Ad-Hoc session)
. 2012-06-20 03:23:32.309 Host name: yyy.dyndns.org (Port: 22)
. 2012-06-20 03:23:32.309 User name: xxx (Password: Yes, Key file: No)
. 2012-06-20 03:23:32.309 Tunnel: No
. 2012-06-20 03:23:32.309 Transfer Protocol: SFTP (SCP)
. 2012-06-20 03:23:32.309 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2012-06-20 03:23:32.309 Proxy: none
. 2012-06-20 03:23:32.309 SSH protocol version: 2; Compression: No
. 2012-06-20 03:23:32.309 Bypass authentication: No
. 2012-06-20 03:23:32.309 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2012-06-20 03:23:32.309 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2012-06-20 03:23:32.309 SSH Bugs: -,-,-,-,-,-,-,-,-
. 2012-06-20 03:23:32.309 SFTP Bugs: -,-
. 2012-06-20 03:23:32.309 Return code variable: Autodetect; Lookup user groups: Yes
. 2012-06-20 03:23:32.309 Shell: default
. 2012-06-20 03:23:32.309 EOL: 0, UTF: 2
. 2012-06-20 03:23:32.309 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2012-06-20 03:23:32.309 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No
. 2012-06-20 03:23:32.309 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2012-06-20 03:23:32.309 Cache directory changes: Yes, Permanent: Yes
. 2012-06-20 03:23:32.309 DST mode: 1
. 2012-06-20 03:23:32.340 Looking up host "yyy.dyndns.org"
. 2012-06-20 03:23:32.465 Connecting to xx.243.yy.212 port 22
. 2012-06-20 03:23:53.494 Failed to connect to xx.243.yy.212: Network error: Connection timed out
* 2012-06-20 03:23:53.494 (ESshFatal) Netzwerkfehler: Zeitgrenze fr Verbindung erreicht.
Regards, HL
Heinz Lindemann
Hi community,
Log is provided.
Any help is appreciated...
Regards, HL
Can you connect using any other SSH client?
