Topic "Recycle bin tab?"
Chris`
if you look at http://winscp.net/eng/docs/ui_login_recycle_bin you can see the "Recycle bin" tab. I can't find this in my WinSCP [4.3.8] installation (see attachment).
What happened with this tab?
Greetings,
Chris`
Description: Recycle bin
In 4.3.8 you need to go to Environment and click Recycle bin link.
Chris`
Thank you Martin!
Pascal Boulerie
Thanks Martin for the explanation.
By the way, the choice of the option is specific to a given server, not to the client itself.
So the option is found in the Login dialog,
via the button "Advanced..."
As indicated in the doc :
http://winscp.net/eng/docs/ui_login_advanced
it is the 2nd option in the Environment section.
Keyword : SFTP
PS For French users, it is the : Poubelle
Pour les utilisateurs francophones, option : Poubelle
