Topic "Prevent Overwriting using Session.GetFiles"
petoefalvi
I want to download files using 'Session.GetFiles'. But this method seems to overwrite existing files in destination folder. Can this be disabled somehow? I havn't found any topic in the documentation or any option for that.
regards,
Michael
So you want to transfer only files that do not exist in the opposite directory?
It's rather a synchronization then.
Use this:
Session.SynchonizeDirectories(SynchronizationMode.Local, localpath, remotepath, false, false, SynchronizationCriteria.None, null);
http://winscp.net/eng/docs/library_session_synchronizedirectories
SP2100
I tried to use your example here so that existing files are not overwritten in local folder , but it's not working. Local file though being new is being replaced by older file from server. Is there any other setting I need to follow?
session.SynchronizeDirectories(SynchronizationMode.Local, localPath, remotePath,false,false, SynchronizationCriteria.None, null);
I am using following statement to get files.
session.GetFiles(remotePath, localPath,false, transferOptions).Check();
Thanks!
Please set Session.SessionLogPath and attach a log showing the problem. Ideally on a very small set (one?) of files.
