Topic "Winscp Remote panel open/edit greyed out"
Reema
When I try to open/edit a file in winscp remote panel, both the options are greyed out. And when I double click it opens the file properties instead of opening the file in edit mode. If I instead copy the file to local folder and double click it works fine.
I checked the preferences:Panel-Double click to edit and also remote panel options. Nothing helps.
I am attaching screenshot of what is greyed out and the settings. Your help is appreciated
I am on version 5.0.7.
There's no screenshot.
Also, can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
