Topic "using WINSCP with FTPS"
I am trying to create an SSIS package with Execute Process task with WinSCP.
I have the following script and I am able to execute the task sucessfully but they file does not appear on the root
of my C:\ drive
option batch on
open ftp://username:password@remotesitename:portnumber
cd ******* < ---- directory on remote site where it is located
option transfer binary
get *.xls C:\
What am I missing?
In my execute task I have C:\Program Files (x86)\WinSCP\ as EXECUTABLE
and -script = C:\FTPSwinsp.txt in the arguments. When I execute the SSIS package it says searching for does not exist Sad
Try defining the local directory in your script?
lcd "C:\"
To generate log file, use /log=path_to_log_file command-line argument. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
