Topic "windows to windows sync"
jgionet76
I'm just getting started in scripting using winscp. (version 4.3.8 Build 1771)
I'm been trying to write a script that'll sync all my remote files with my local files. So far I haven't had much luck.
Here is my script:
option batch off
# Connect - format: user:password@host
open myusername:mysecretpassword@www.myproductionserver.something
synchronize remote -delete -mirror -nopermissions "S:\webs\staging.myserver.something\htdocs\mysubfolder" "/D:/web/roots/proweb19/wwwroot/asubfolder/mysubfolder"
# Disconnect
close
# Exit WinSCP
Now I'll place a TXT file in the mysubfolder of my LOCAL server and the file NEVER makes its way to the remote server.
I've tried the above command, plus tried taking out -mirror and -nopermission and still no luck.
When I use the GUI all of this works like a charm.
I've attached my log file.
sync.log (6.22 KB) [Download]
Description: log file
jgionet76
I just tested the same script with the latest BETA release and I'm still getting the same results. No file syncing is occurring.
Please post a log file using the GUI with the same version of WinSCP.
