Topic "Error during creating a directory on a SFTP Server"
I have to create a directory on a SFTP Server. I use the .net assemby 5.0.7.
Dim ComResult As WinSCP.CommandExecutionResult
 comResult = session.ExecuteCommand("MKDIR " & strRemoteDir & strDirZeitstempel)
catch ex as Exception
End Try
I get this error message:
{WinSCP.SessionLocalException: Element "call" not found in the log file" & vbCrLf & " bei WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags)" & vbCrLf & " bei WinSCP.CustomLogReader.WaitForNonEmptyElementAndCreateLogReader(String localName, LogReadFlags flags)" & vbCrLf & " bei WinSCP.Session.ExecuteCommand(String command)" & vbCrLf & " bei Export.ExportFiles() in C:\_.NET\x.vb:Zeile 146.}
Is there any way to create a directory on a SFTP Server with .net?
Olaf Very Happy
See remarks section on Session.ExecuteCommand article to understand why you possibly cannot use it.
Also check session log file (or attach it here).
This bug is a cause, why you are getting the strange error message:
