Topic "Automation problem with SQL Agent."
David.Dx
Hi all,
I have some problem with WinSCP when I want to use it with SQL Agent.
I have a SSIS package which use WinSCP with an "Execute Process Task" toolbox.
The package runs with success.
When I put my package on my SQL Server File System it still works correctly.
But when I try pour launch my package with SQL Agent (in order to automate the job), the job starts and run without end.
Please read FAQ:
http://winscp.net/eng/docs/faq_scheduler
If that does not help, come back.
David.Dx
Unfortunately I'm already doing this.
Here's my command line:
/command "option batch on" "option confirm off" "option transfer binary"
"open sftp://[Login]:[Password]@[Host]:[Port] -hostkey=""ssh-dss 1024 [HostKey]"" -timeout=120"
"cd /incoming" "put -nopreservetime -nopermissions [FilePath]" "exit"
[xxx] are variable name in SSIS
Note: When I execute my package using dtexec.exe nothing goes wrong
So please post a log files both from successful and failed session.
David.Dx
Sorry for the answer time I was pretty busy.
I'm adding log file to my process and I post this.
David.Dx
Unfortunately, the job run with SQL Agent doesn't generate any log file.
So this means that WinSCP is not launch.
WinSCP is not the problem.
Thanks for the help.
David.Dx
I finnaly found the solution
http://social.msdn.microsoft.com/forums/en-US/sqlintegrationservices/thread/da9c4117-8f43-4c61-a1b8-6214fdb97118/
UNC file path are not my friends anymore ...
