Topic "Timeout trying to connect from IIS/ASP"
Xanrag
I have a small section of code in VBA as follows:
Dim oSessionOptions, oSession
   Set oSessionOptions = WScript.CreateObject("WinSCP.SessionOptions")
   With oSessionOptions
      .Protocol = 0 'Protocol_Sftp
      .HostName = "10.112.5.148"
      .UserName = "ababab"
      .Password = "bababa"
      .SshHostKey = "ssh-rsa 1024 bc:96:db:86:fc:10:e4:00:45:21:5f:2f:a6:94:39:02"
   End With
   Set oSession = WScript.CreateObject("WinSCP.Session")
   oSession.DebugLogPath = "c:\logs\sftp-debug.log"
   oSession.SessionLogPath = "c:\logs\sftp.log"
   oSession.Open oSessionOptions
   oSession.Dispose
.. It works just fine when I run it as a vbscript file from the commandline. However when I try to run it in an ASP file (classic ASP) it gets a timeout. (After I replaced WScript with Server in the above code)
When it works the relevant debug log section looks like this:
[2012-07-11 21:32:01Z] [0003]     Scheduling output: [Starting the session...]
[2012-07-11 21:32:01Z] [0003]   ExeSessionProcess.ProcessEvent leaving
[2012-07-11 21:32:01Z] [0001]     Output: [Starting the session...]
[2012-07-11 21:32:01Z] [0003]   ExeSessionProcess.ProcessEvent entering
[2012-07-11 21:32:01Z] [0003]     Scheduling output: [Reading remote directory...]
[2012-07-11 21:32:01Z] [0001]     Output: [Reading remote directory...]
[2012-07-11 21:32:01Z] [0003]     Scheduling output: [Session started.]
[2012-07-11 21:32:01Z] [0001]     Output: [Session started.]
[2012-07-11 21:32:01Z] [0003]     Scheduling output: [Active session: [1] ababab@10.112.5.148]
[2012-07-11 21:32:01Z] [0001]     Output: [Active session: [1] ababab@10.112.5.148]
[2012-07-11 21:32:01Z] [0003]     ExeSessionProcess.ProcessInputEvent entering
[2012-07-11 21:32:01Z] [0001]   CallstackAndLock..ctor leaving
[2012-07-11 21:32:01Z] [0001]   Result []
[2012-07-11 21:32:01Z] [0001] Session.System.Reflection.IReflect.InvokeMember leaving
[2012-07-11 21:32:01Z] [0001] Session.System.Reflection.IReflect.InvokeMember entering
[2012-07-11 21:32:01Z] [0001]   Name [Dispose]
[2012-07-11 21:32:01Z] [0001]   Target [WinSCP.Session]
And when it doesn't work it looks like this:
[2012-07-11 22:07:54Z] [0003]     Scheduling output: [Starting the session...]
[2012-07-11 22:07:54Z] [0003]   ExeSessionProcess.ProcessEvent leaving
[2012-07-11 22:07:54Z] [0003]   ExeSessionProcess.ProcessEvent entering
[2012-07-11 22:07:54Z] [0003]     Scheduling output: [Reading remote directory...]
[2012-07-11 22:07:54Z] [0003]     Scheduling output: [Session started.]
[2012-07-11 22:07:54Z] [0003]     Scheduling output: [Active session: [1] ababab@10.112.5.148]
[2012-07-11 22:07:54Z] [0003]     ExeSessionProcess.ProcessInputEvent entering
[2012-07-11 22:08:54Z] [0001]     Exception: System.TimeoutException: Timeout waiting for WinSCP to respond.
   at WinSCP.Session.CheckForTimeout()
   at WinSCP.Session.Open(SessionOptions sessionOptions)
[2012-07-11 22:08:54Z] [0001]     Session.Cleanup entering
[2012-07-11 22:08:54Z] [0001]       Command: [exit]
[2012-07-11 22:08:54Z] [0001]       ExeSessionProcess.ExecuteCommand entering
[2012-07-11 22:08:54Z] [0001]       ExeSessionProcess.ExecuteCommand leaving
[2012-07-11 22:08:54Z] [0003]       Scheduling output: [winscp> exit]
[2012-07-11 22:08:54Z] [0003]     ExeSessionProcess.ProcessInputEvent leaving
[2012-07-11 22:08:54Z] [0003]   ExeSessionProcess.ProcessEvent leaving
[2012-07-11 22:08:54Z] [0001]       ExeSessionProcess.Close entering
[2012-07-11 22:08:54Z] [0001]       ExeSessionProcess.Close leaving
[2012-07-11 22:08:54Z] [0001]       ExeSessionProcess.Dispose entering
[2012-07-11 22:08:54Z] [0003] ExeSessionProcess.ProcessEvents leaving
[2012-07-11 22:08:54Z] [0001]       ExeSessionProcess.Dispose leaving
[2012-07-11 22:08:54Z] [0001]     Session.Cleanup leaving
[2012-07-11 22:08:54Z] [0001]   CallstackAndLock..ctor leaving
[2012-07-11 22:08:54Z] [0001]   Error [System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.TimeoutException: Timeout waiting for WinSCP to respond.
   --- End of inner exception stack trace ---
   at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
   at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
   at System.RuntimeType.InvokeMember(String name, BindingFlags bindingFlags, Binder binder, Object target, Object[] providedArgs, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParams)
   at WinSCP.Session.System.Reflection.IReflect.InvokeMember(String name, BindingFlags invokeAttr, Binder binder, Object target, Object[] args, ParameterModifier[] modifiers, CultureInfo culture, String[] namedParameters)]
[2012-07-11 22:08:54Z] [0001] Session.System.Reflection.IReflect.InvokeMember leaving
Any tips on what I should look at? Permission for the account running IIS? COM rights etc?
The reason it is old classic ASP is that it is an old project that due to policy has to switch from FTP to SFTP and the old control does not support it.
vbs.txt (9.72 KB) [Download]
Description: Put sftp.log from both runs here since max attachments was 3.
vbs-debug.txt (12.47 KB) [Download]
Description: (none)
asp-debug.txt (12.41 KB) [Download]
Description: (none)
Xanrag
I used the debug vertsion and mailed you the output, but it did not shed any light on the problem.
I didn't give up though and I found a way to make it work (although not quite an acceptable one in production). If I make both the IWAM_ and the IUSR_ accounts members of the administrators group the strange delay does not happen, so there must be some rights that the user is missing without it.
