Topic "keepuptoday - You will be disconnected after 15 minutes"
I am using the keepuptodate command in script. It is working fine.
But I am facing a problem about the below thing
You will be disconnected after 15 minutes of inactivity
so because of the following reason, my script gets aborted after 15 mins. But my requirement is to increase that time to quite a bit or reconnects automatically how do I do that, please
Thanks!
Do you have keepalives turned on?
http://winscp.net/eng/docs/ui_login_connection
Thanks Martyn.
I will try making keepalive on and update you.
Thanks!
