Topic "Error by session.ExecutablePath"
oli001
I have VS.net 2010 and the Assembly WINSCP.dll is sucessfully integrated.
WinSCP ist NOT installed on my System.
I set session.ExecutablePath = "D:\\winscp507\\"; - here is the file winscp.exe
But I got the Exception: "WinSCP.SessionLocalException: D:\winscp507\ does not exists."
If I set the path to "D:\\winscp507\\winscp.exe"; I get the Exception: "System.IO.FileNotFoundException: D:\Entwicklung C"
First the path in Executable path is not the path the FNF-Exception shows, second: the path nomally is D:\Entwicklung C#\...
Thanks for help.
Oli
You should set the ExecutablePath to path to .exe (your second variant), not to path to containing directory.
Please set Session.DebugLogPath and attach or email me the log.
oli001
The problem was the '#'!
After renaming the folder in "Entwicklung DotNet\...." it works fine.
But I have another question:
The SSL/TLS certificate needs the key from server. Is it possible to trust always, without put the key in the variable?
Thanks for help,
Oli
Thanks for sharing this. I'll try to reproduce the problem.
If the certificate is untrusted, WinSCP .NET assembly won't connect. So you need to set the SessionOptions.SslCertificate. If that's what you ask for.
I wasn't able to reproduce the problem with FileNotFoundException.
I have emailed you a link to a debug version of the assembly.
Hiro.A
Hi.
(I am Japanese and please forgive me if my english is poor..)
I also got the same error.
I guess the main reason of this issue is that my environment of my c# binaries was @"I:\VC# Projects\C#2010\scptest\scptest\bin\Debug\".
This issue may raised if C# binary's path has any "#" characters.
Would you modify this assembly to accept it ?
Thank you for offering this fantastic programs!
Thanks for report post.
http://winscp.net/tracker/show_bug.cgi?id=935
