Topic "Delete directory recursively"
oli001
how can I delete a directory recursively?
with session.executeCommand("RD ....") I cant't delete folders that are not empty.
is the only possibility wirting a recursive function that removes all files and then deleting directories?
Thank you,
Oli
There's no official way.
Added to tracker:
http://winscp.net/tracker/show_bug.cgi?id=887
You may achieve that with Session.ExecuteCommand. But the solution is protocol-dependent. I do not know, what protocol you are using. If FTP (seems so from RD command), there's probably no way.
