Topic "cant copy Files"
I try to use WinSCP 3.5.6 Build 213 and there seems to be a problem copy files from one of oure servers to the pc.
This server runs with suse linux 8.2 and SSH-1.99-OpenSSH_3.4p1.
In the Logfile from WinSCP are a lot of "not found" enties after connecting the server.
The connection ist only possible with ssh 1.
I do not understand what you mean by "lot of "not found" enties". Can you post a log file or at least an error message?
there are entries like this:
Using SCP protocol.
> echo "WinSCP: this is end-of-file:0"
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
. Trying "$?".
> echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$?" selected.
. Clearing all aliases.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 4: unalias: echo: not found
< WinSCP: this is end-of-file:1
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 5: unalias: pwd: not found
> unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 6: unalias: cd: not found
> unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 7: unalias: ls: not found
> unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
That is normal, no problem. Please post a log file where problem with "copy" is shown.
