Topic "Code to upload and download files via SFTP using WinSCP"
dwinn86
I have developed a website that allows users to upload/download files to and from an FTP server.
The requirements have now been changed in that the files need to be uploaded and downloaded using SFTP.
I have downloaded WinSCP and set it up to connect to my FTP server.
I am now stumped though as to what I need to change or add in to my Visual Studio VB.Net project.
I have read that I need to create a SessionOptions class that stores the authentication details, but still dont understand how this is supposed to work.
Below is the code I have:
Imports System
Imports WinSCP
Imports System.Globalization
Imports System.IO
Public Class SessionOptions
    Dim HostName As String
    Dim UserName As String
    Dim Password As String
    Public Shared Function Main() As Integer
        Try
            ' Setup session options
            With sessionOptions
                '.Protocol = Protocol.Sftp
                .HostName = "XX.XX.XX.XX"
                .UserName = "user"
                .Password = "password"
            End With
            Using session As Session = New Session
                ' Connect
                session.Open(sessionOptions)
                ' Upload files
                transferResult = session.PutFiles(FileUpload1.SelectedItem, False, transferOptions)
                ' Throw on any error
                transferResult.Check()
                ' Print results
                Dim transfer As TransferEventArgs
                For Each transfer In transferResult.Transfers
                    Console.WriteLine("Upload of {0} succeeded", transfer.FileName)
                Next
            End Using
            Return 0
        Catch e As Exception
            Console.WriteLine("Error: {0}", e)
            Return 1
        End Try
    End Function
End Class
How would I now do the code to be able to upload and download files using SFTP from my .aspx forms that I have created.
All help and advice will be much appreciated.
Dwinn86
lynzepiper
dwinn86
Hello lynzepiper,
Thank you for your reply.
Would you mind elaborating a little bit more?
Do you mean providing 3 parameters for my function, so it would be: Public Shared Function Main(Hostname as String, User As String, Password As String) As Integer etc?
And then from my .aspx page, within the subroutine that does the upload and download, I call function 'Main' and provide it with the 3 parameters?
Or do you mean something else?
Thanks again
lynzepiper
dwinn86
Thank you very much for your reply.
I have been looking over your code for the last couple of hours.
Would I need to put this code in to a new class or could I put it all in the subroutine that uploads and downloads the files (.aspx page)?
Many thanks again.
lynzepiper
dwinn86
I have now put the code in the code behind page...declared a function that takes the connection details as the parameters.
When I go to declare the connection details: .HostName, .UserName, .Password, I get a message for each saying they are not a member of FTPUploadSite.SessionOptions.
Can you please tell me what I am doing wrong?
My code is as follows:
Quote:
Imports System.Net
Imports System.IO
Imports WinSCP
Public Class InDirectory
Inherits System.Web.UI.Page
Dim InDirectory As Object
Public Shared Function ProcessFiles(HostName As String, UserName As String, Password As String, LocalPath As String, RemotePath As String) As Integer
Dim Path As String
Path = "C:\Program Files\WinSCP\WinSCP.exe"
Try
With sessionOptions
.HostName = "xx.x.xx.xx"
.UserName = "user"
End With
'Set up the session
' Connect
session.ExecutablePath = Path
' Upload files
If (session.Opened) Then
transferResult = session.PutFiles(FileUpload1.SelectedItem, True, transferOptions)
End If
' Print results
Next
End Using
Return 0
Return 1
End Try
End Function
End Class
Am I setting up the SessionOptions in the wrong place?
Many thanks[/quote]
lynzepiper
dwinn86
Sorry, what code would you like to see?
Where I upload the files?
lynzepiper
dwinn86
I am not calling process files at the moment.
I would need to use that in my routine where I upload the file wouldnt I?
dwinn86
Sorry, as you can tell...I am trying to learn this as not worked with it before.
I areally appreciate your help though, thank you.
lynzepiper
dwinn86
Thank you for that.
To upload the filename specified in my combo box, woul I use: session.PutFiles(UploadFile1.SelectedItem.text, "/", True, transferOptions)
Then in my routine on my.aspx page, I do a call for ProcessFiles()?
lynzepiper
dwinn86
I only want to do SFTP.
Ok, this is the code I have for the Upload method in my.aspx page.
Does this look correct? or am I missing something:?
Quote:
Protected Sub butUpload_Click(ByVal sender As Object, ByVal e As EventArgs) Handles butUpload.Click
'Declaring the path of where the file should be uploaded to on the FTP site.
'Dim ftp As FtpWebRequest = DirectCast(WebRequest.Create("ftp://XX.X.XX.XX/In/" + FileUpload1.FileName), FtpWebRequest)
Dim objOutlook As Object
Dim objOutlookMsg As Object
'If no file has been selected, give error message.
If FileUpload1.HasFile = False Then
MsgBox("A file needs to be selected!")
End If
'If a file has been selected, carry out the file upload process.
If FileUpload1.HasFile = True Then
Try
ProcessFiles()
Const olMailItem = 0
'The importance level of the email.
Const olImportanceHigh = 1
'Who the email is going to.
Const olTo = 1
objOutlook = CreateObject("Outlook.Application")
'Creating new mail item.
objOutlookMsg = objOutlook.CreateItem(olMailItem)
'Declaring the directory to read the file from.
Dim sftpFileStream As New FileStream("C:\" + FileUpload1.FileName, FileMode.Open)
'Getting the length of the file.
Dim sftpBuffer(sftpFileStream.Length) As Byte
'Reading in the file.
sftpFileStream.Read(sftpBuffer, 0, sftpFileStream.Length)
'SCRIPT TO SEND EMAIL GOES HERE!
With objOutlookMsg
'The email address of the recipient.
Dim objOutlookRecip As Object = .Recipients.Add("emailaddress")
objOutlookRecip.type = olTo
'Declaring the subject of the email.
.Subject = "FTP File Upload Confirmation"
'Declaring what will be in the email.
.Body = "Hello, this is confirmation that the file: " + FileUpload1.FileName + " has been uploaded successfully..."
.Importance = olImportanceHigh
'Sending the email.
.send()
End With
objOutlookMsg = Nothing
objOutlook = Nothing
Catch ex As Exception
MsgBox("File: " + FileUpload1.FileName + " has been uploaded...")
End Try
End If
End Sub
Thank you once again for your help and patience.
Much appreciated.
lynzepiper
dwinn86
No I havent yet.
Do I need to pass it the Hostname, username, password etc?
lynzepiper
dwinn86
My ProcessFiles() doesnt require any parameters...I am setting the values of the Hostname, UserName and Password within the function.
I have seen ona few forums that people specify the hostkey as well when creating a session, but I do not know how to get that detail?
Would you be able to advise on that at all?
Many thanks
dwinn86
I have just run the site, gone in to upload a file, and before I get to the form, I get an error saying that:
Quote:
Compiler Error Message: BC30451: 'ProcessFiles' is not declared. It may be inaccessible due to its protection level.
Why is this happening?
lynzepiper
dwinn86
It is called Public Shared Function ProcessFiles() As Integer
It is in the InDirectory.aspx.vb - my code behind class.
lynzepiper
dwinn86
I have changed it to private, protected and protected friend and I get the same error message.
Also, In the code behind page, im getting an error for .Protocol, .HostName, .UserName, .Password, .FtpMode, .sshHostkey.
Each one is saying that they are not a member of FTPUploadSite.SessionOptions.
What do I need to do to make them members?
lynzepiper
dwinn86
I am not passing parameters...I am literally just calling ProcessFiles() in my .aspx page
Would it be wise if I use parameters then?
What I dont understand is that it picks up the function name, but is saying it is not declared.
What if I copy the session code from the code behind page (.aspx.vb) and just paste it under my main upload routine in my .aspx page?
lynzepiper
dwinn86
I have just moved the script in to my .aspx page and it now accesses the function with no problems but is saying that
Quote:
Compiler Error Message: BC30002: Type 'SessionOptions' is not defined.
Pointing to this line of code:
Any ideas?
Again, thank you so much for helping me with this.
lynzepiper
dwinn86
That is not a problem...I am kind of a newbie myself Smile
My codebehind script is as follows:
Imports System.Net
Imports System.IO
Imports WinSCP
    Protected Function ProcessFiles() As Integer
        Dim Path As String
        Try
            With sessionOptions
                .Protocol = Protocol.sFtp
                .UserName = "user"
                .FtpMode = FtpMode.Passive
                .SshHostKey = "ssh-rsa xxxx xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
            End With
            'Set up the session
                ' Connect
                ' Upload files
                    transferResult = session.PutFiles(FileUpload1.SelectedItem, "/", True, transferOptions)
                End If
                ' Print results
                    Console.Read()
                Next
            End Using
            Return 0
            Return 1
        End Try
    End Function
End Class
My main .aspx form is as follows:
<%@ Page Language="vb" AutoEventWireup="false" CodeBehind="InDirectory.aspx.vb" Inherits="FTPUploadSite.InDirectory" %>
<%@ Import Namespace="FTPUploadSite" %>
<%@ Import Namespace="System.IO" %>
<%@ Import Namespace="System.Net" %>
<%@ Import Namespace="System" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title></title>
    <style type="text/css">
        .style1
            font-family: Arial;
            font-size: xx-large;
    </style>
</head>
<body style="height: 797px; width: 1621px; background-color: #CCFFFF">
    <form id="form1" runat="server">
    <div class="style1" style="text-align: center">
        FTP In Directory</div>
    <p>
        &nbsp;</p>
        <script runat="server">
                'Dim ftp As FtpWebRequest = DirectCast(WebRequest.Create("ftp://xx.x.xx.xx/In/" + FileUpload1.FileName), FtpWebRequest)
                End If
                    Try
                        ProcessFiles()
                        'ftp.Credentials = New System.Net.NetworkCredential("dwinn", "america86")
                        'ftp.KeepAlive = False
                        'ftp.Timeout = 20000
                        'ftp.Method = System.Net.WebRequestMethods.Ftp.UploadFile
                        'ftp.UseBinary = True
                        Const olTo = 1
                        MsgBox("Carrying On")
                        'Upload the file
                        'Dim ftpGetStream As Stream = ftp.GetRequestStream()
                        'ftpGetStream.Write(ftpBuffer, 0, ftpFileStream.Length)
                        'Closes off connections.
                        'ftpGetStream.Close()
                        'ftpFileStream.Close()
                        'Getting a response from the FTP site.
                        'Dim ftpResponse As FtpWebResponse = CType(ftp.GetResponse(), FtpWebResponse)
                        With objOutlookMsg
                            Dim objOutlookRecip As Object = .Recipients.Add("dwinn@email.co.uk")
                            'Sending the email.
                            .send()
                        End With
                    End Try
                End If
            End Sub
            Protected Sub butDirectories_Click(ByVal sender As Object, ByVal e As EventArgs) Handles butDirectories.Click
                'Takes the user to the FTP Directories screen.
                Response.Redirect("form1.aspx")
            End Sub
            Protected Sub butSystemLogOut(ByVal sender As Object, ByVal e As EventArgs) Handles butSysLogOut.Click
                'Takes the user to the User Login screen.
                Response.Redirect("form2.aspx")
            End Sub
                Dim Path As String
                Try
                    With sessionOptions
                        .UserName = "user"
                        .SshHostKey = "ssh-rsa xxxx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
                    End With
                    'Set up the session
                        ' Connect
                        ' Upload files
                        End If
                        ' Print results
                            Console.Read()
                        Next
                    End Using
                    Return 0
                    Return 1
                End Try
            End Function
        </script>
    <p>
        &nbsp;</p>
    <p>
        &nbsp;</p>
    <p>
        &nbsp;</p>
    <p style="text-align: center">
        <asp:FileUpload ID="FileUpload1" runat="server" />
&nbsp;
        </p>
        &nbsp;</p>
        &nbsp;</p>
        <asp:Button ID="butUpload" runat="server" Text="Upload File" />
    &nbsp;
    &nbsp;<asp:Button ID="Button4" runat="server"
            PostBackUrl="ftp://xx.x.xx.xx/user/In/" style="margin-left: 1px"
            Text="FTP List" />
    &nbsp;&nbsp;
        <asp:Button ID="butDirectories" runat="server" Text="Back to FTP Directories"
            Width="176px" />
&nbsp;&nbsp;
        <asp:Button ID="butSysLogOut" runat="server" Text="Exit the system"
            Width="176px" />
    </p>
        &nbsp;
    </p>
        &nbsp;</p>
&nbsp;</p>
        &nbsp;</p>
        &nbsp;</p>
        &nbsp;</p>
    </form>
</body>
</html>
Again, many thanks to you for everything Smile
lynzepiper
dwinn86
Ok then, I have it all back in to the code behind page.
How do I reference WinSCP in my .aspx page?
<%@ Import Namespace="WinSCP" %> ?
lynzepiper
dwinn86
Thanks for that...changed it now.
In my code behind page it is referenced as:
Imports WinSCP
But it is saying that it has no public members of can not be found.
Do you know how this can be rectified?
lynzepiper
dwinn86
No I havent, do I need to add it as a reference from Visual Studio?
lynzepiper
dwinn86
I see, becasue I havent set up a reference to WinSCP, it wont allow .Hostname, .User etc etc because there are no public members set up yet?
I have done that, gone to the WinSCP on my local drive and can only see DragExt.dll
There are no other .dll files there.
Does that mean I will have to download it?
lynzepiper
dwinn86
I have now done this, added it as a reference, it is now happy with the parameters I am providing.
When I run the website now, i get an error message that says:
Quote:
Parser Error Message: Could not load type 'FTPUploadSite.Global_asax'.
Pointing to this page:
Line 1:  <%@ Application Codebehind="Global.asax.vb" Inherits="FTPUploadSite.Global_asax" Language="vb" %>
Do you know what this means?
dwinn86
I managed to figure that part out.
I have now got another issue where I load the site, go in to upload the file, but as I get to the form, I get the following error:
Quote:
Parser Error Message: 'FTPUploadSite.InDirectory' is not allowed here because it does not extend class 'System.Web.UI.Page'.
Its pointing to the following in my InDirectory.aspx page:
Line 1:  <%@ Page Language="vb" AutoEventWireup="false" CodeBehind="InDirectory.aspx.vb" Inherits="FTPUploadSite.InDirectory" %>
Do you know what this could be at all?
lynzepiper
dwinn86
How would I do that?
Public Clas InDirectory Inherits System.Web.UI.Page?
I have just tried that but I get a message saying end of statement expected.
Or does it need to be somewhere else?
lynzepiper
lynzepiper
dwinn86
Thanks I have got the site now opening, but when I try to upload a file, I select the file to upload but nothing happens.
I have put a message box within the ProcessFiles() function and its not coming out with the message.
It is as if it is not seeing the function call there.
I dont suppose you can advise on this as well?
lynzepiper
dwinn86
I am now getting an error saying that ProcessFiles has not been declared.
I am so glad the change was requested now Razz
lynzepiper
When is it saying this? What access level does ProcessFiles have?
dwinn86
When I call ProcessFiles() it is underlined and sayd not declared.
Protected Function ProcessFiles() As String
[/code]
lynzepiper
dwinn86
This is my main .aspx page:
<%@ Import Namespace="System.Web.UI.Page" %>
    <title></title>
        .style1
            font-family: Arial;
    </style>
</head>
    <p>
        &nbsp;</p>
                'Dim ftp As FtpWebRequest = DirectCast(WebRequest.Create("ftp://xx.xx.xx.xx/In/" + FileUpload1.FileName), FtpWebRequest)
                End If
                    Try
                        MsgBox ("About to process")
                        ProcessFiles()
                        'ftp.Credentials = New System.Net.NetworkCredential("user", "password")
                        Const olTo = 1
                        'Dim sftpFileStream As New FileStream("C:\FTPDirectoryFiles\" + FileUpload1.FileName, FileMode.Open)
                        'Dim sftpBuffer(sftpFileStream.Length) As Byte
                        'sftpFileStream.Read(sftpBuffer, 0, sftpFileStream.Length)
                        'Upload the file
                        With objOutlookMsg
                            'Sending the email.
                            .send()
                        End With
                    End Try
                End If
            End Sub
                Response.Redirect("FTPDirectories.aspx")
            End Sub
                Response.Redirect("UserLogin.aspx")
            End Sub
        </script>
    <p>
        &nbsp;</p>
    <p>
        &nbsp;</p>
    <p>
        &nbsp;</p>
&nbsp;
        </p>
        &nbsp;</p>
        &nbsp;</p>
    &nbsp;
            PostBackUrl="ftp://xx.x.xx.xx/dwinn/In/" style="margin-left: 1px"
            Text="FTP List" />
    &nbsp;&nbsp;
            Width="176px" />
&nbsp;&nbsp;
            Width="176px" />
    </p>
        &nbsp;
    </p>
        &nbsp;</p>
&nbsp;</p>
        &nbsp;</p>
        &nbsp;</p>
        &nbsp;</p>
    </form>
</body>
</html>
This is my code behind page:
Imports System.Net
Imports System.IO
Imports WinSCP
        Dim Path As String
        Try
            MsgBox("Processing")
            With sessionOptions
                .HostName = "ftp://xx.x.xx.xx"
                .UserName = "user"
            End With
            'Set up the session
                ' Connect
                ' Upload files
                    transferResult = session.PutFiles(FileUpload1.ToString, "/", True, transferOptions)
                End If
                ' Print results
                    Console.Read()
                Next
            End Using
            Return 0
            Return 1
        End Try
    End Function
End Class
Thanks for being patient with me
lynzepiper
dwinn86
Could you please elaborate?
lynzepiper
dwinn86
Ok then, so to clarify, ALL of my VB code (routines etc) should all be put in to my code behind and only leave the HTML code and ASP.Net code in my webform??
lynzepiper
dwinn86
Does that mean that when I go on to the page and select the file to upload, the program will automatically look in to the code behind form and then go through all the code?
I asumed it just went through the .aspx page?
lynzepiper
dwinn86
Thank you.
I will have a go at doing that when I get back in to work tomorrow.
When I do projects from now on is it best to keep that in mind?
The .aspx webform keeps your ASP and HTML code and then the code behind form (aspx.vb) keeps all of your vb code?
So your sub-routines, functions etc?
Keep your VB code sperate from your actual interface code?
lynzepiper
dwinn86
To be honest with you...I am self taught at VB in Visual Studio...never been taken through best practises or anything.
That is why I have been submitting a lot of threads Smile
What exceptions are they?
dwinn86
Heya, im back again...
I have got the site going, and am trying to upload a file, but it seems that the session isnt able to open the session options?
The code is:
        Dim Path As String
        Try
            With sessionOptions
                '.PortNumber = 22
                .UserName = "user"
                '.SshHostKey = "ssh-rsa xxxx xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
            End With
            'Set up the session
            'Using session As Session = New Session
            Dim mySession As New Session
                ' Connect
            MsgBox("Connecting")
            mySession.ExecutablePath = Path
            mySession.Open(sessionOptions)
                'Dim transferResult As TransferOperationResult
                ' Upload files
                'Dim transferOptions As New TransferOptions
                ' Print results
                'Dim transfer As TransferEventArgs
                'For Each transfer In transferResult.Transfers
                'Console.WriteLine("Upload of {0} succeeded", transfer.FileName)
                'Console.Read()
                'Next
                MsgBox("About to upload")
            If (mySession.Opened) Then
                MsgBox("Uploading")
                'TransferOptions.TransferMode = TransferMode.Binary
                'transferResult = session.PutFiles(FileUpload1.ToString, "/", True, transferOptions)
                'transferResult = session.PutFiles(FileUpload1.ToString, "ftp://xx.x.xx.xx/In/", False, TransferOptions)
                'transferResult.Check()
            End If
            'End Using
            Return 0
            Return 1
        End Try
    End Function
I dont suppose you can help advise why this is?
Many thanks
dwinn86
I have managed to get the connection now going, but for some reason, it goes through the entire process of uploading the file.
But it doesnt seem to actually upload the file.
This is the code I have for uploading.
                MsgBox("Uploading")
                transferResult = mySession.PutFiles("C:\FTPDirectoryFiles\" + FileUpload1.FileName, "ftp://user:password@xx.x.xx.xx/In/", False, transferOptions)
            End If
If you could advise, that would be great.
Many thanks again.
