ftp logins are corrupted
unsalkorkmaz
I had no problem till 1-2 weeks ago. My backup ftp's server got hardware problem, they changed it and my problems started if i remember correct. First i thought its ftp server's wrong settings but after i switch to new hosting company , i still get same problem in new ftp account too. Basically when i login i am getting directly this error:
GetPeerName failed
Entering Passive Mode (IP,IP,IP,IP,236,50).
I can successfully login via ftpzilla but winscp started to give this error in ftp logins :S
sftp logins dont have problem.
(PS: i am using socks5 proxy)
Re: ftp logins are corrupted
Please attach a full log file showing the problem.
unsalkorkmaz
WinSCP Version 5.0.8 (Build 2438) (OS 6.1.7601 Service Pack 1)
Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
Local account: korkmaz-PC\korkmaz
Login time: 13 Ağustos 2012 Pazartesi 11:41:50
Session name: user@backup-server.tld (Modified stored session)
Host name: user.backup-server.tld (Port: 21)
User name: user (Password: Yes, Key file: No)
Tunnel: No
Transfer Protocol: FTP
Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
Proxy: SOCKS5
HostName: localhost (Port: 3121); Username: ; Passwd: No
FTP: FTPS: None; Passive: Yes [Force IP: A]
Local directory: C:\Users\korkmaz\Documents, Remote directory: /, Update: Yes, Cache: Yes
Cache directory changes: Yes, Permanent: Yes
DST mode: 1
Connecting to user.backup-server.tld ...
Connected with user.backup-server.tld. Waiting for welcome message...
220 ProFTPD 1.3.4b Server (Hetzner Backup) [::ffff:IP.IP.IP.IP]
USER user
331 Password required for user
PASS ****************
230 User user logged in
SYST
215 UNIX Type: L8
FEAT
211-Features:
 MDTM
 MFMT
 TVFS
 AUTH TLS
 MFF modify;UNIX.group;UNIX.mode;
 MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
 PBSZ
 PROT
 REST STREAM
 SIZE
211 End
Connected
Using FTP protocol.
Doing startup conversation with host.
PWD
257 "/" is the current directory
Changing directory to "/".
CWD /
250 CWD command successful
Getting current directory name.
PWD
Retrieving directory listing...
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (IP,IP,IP,IP,238,203).
GetPeerName failed
TYPE A
200 Type set to A
PASV
227 Entering Passive Mode (IP,IP,IP,IP,230,216).
GetPeerName failed
(ECommand) Error listing directory '/'.
GetPeerName failed
Startup conversation with host finished.
unsalkorkmaz
your mail was in spam folder, fyi.
i tried it but got directly connection error:
. 2012-08-13 20:52:53.690 --------------------------------------------------------------------------
. 2012-08-13 20:52:53.691 WinSCP Version 5.0.8 (Build 2439) (OS 6.1.7601 Service Pack 1)
. 2012-08-13 20:52:53.691 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2012-08-13 20:52:53.691 Local account: korkmaz-PC\korkmaz
. 2012-08-13 20:52:53.691 Login time: 13 Ağustos 2012 Pazartesi 20:52:53
. 2012-08-13 20:52:53.691 --------------------------------------------------------------------------
. 2012-08-13 20:52:53.691 Session name: user@backup.tld (Modified stored session)
. 2012-08-13 20:52:53.691 Host name: user.backup.tld (Port: 21)
. 2012-08-13 20:52:53.691 User name: user (Password: Yes, Key file: No)
. 2012-08-13 20:52:53.691 Tunnel: No
. 2012-08-13 20:52:53.691 Transfer Protocol: FTP
. 2012-08-13 20:52:53.692 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2012-08-13 20:52:53.692 Proxy: SOCKS5
. 2012-08-13 20:52:53.692 HostName: localhost (Port: 3121); Username: ; Passwd: No
. 2012-08-13 20:52:53.692 FTP: FTPS: None; Passive: Yes [Force IP: A]
. 2012-08-13 20:52:53.692 Local directory: C:\Users\korkmaz\Documents, Remote directory: /, Update: Yes, Cache: Yes
. 2012-08-13 20:52:53.692 Cache directory changes: Yes, Permanent: Yes
. 2012-08-13 20:52:53.692 DST mode: 1
. 2012-08-13 20:52:53.692 --------------------------------------------------------------------------
. 2012-08-13 20:52:53.760 Connecting to user.backup.tld ...
. 2012-08-13 20:52:53.765 Connection failed.
* 2012-08-13 20:52:53.818 (EFatal) Connection failed.
* 2012-08-13 20:52:53.818 Connection failed.
unsalkorkmaz wrote:
getting directly connection error like previous debug version :S
btw i can make a video that showing problem if you want/need.
Can you email me the log?
unsalkorkmaz
. 2012-08-23 16:04:21.584 --------------------------------------------------------------------------
. 2012-08-23 16:04:21.584 WinSCP Version 5.0.8 (Build 2490) (OS 6.1.7601 Service Pack 1)
. 2012-08-23 16:04:21.585 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2012-08-23 16:04:21.585 Local account: korkmaz-PC\korkmaz
. 2012-08-23 16:04:21.585 Working directory: C:\Program Files\WinSCP
. 2012-08-23 16:04:21.585 Command-line: "C:\Program Files\WinSCP\WinSCP.exe"
. 2012-08-23 16:04:21.585 Login time: 23 Ağustos 2012 Perşembe 16:04:21
. 2012-08-23 16:04:21.585 --------------------------------------------------------------------------
. 2012-08-23 16:04:21.585 Session name: user@user.your-backup.de (Modified stored session)
. 2012-08-23 16:04:21.585 Host name: user.your-backup.de (Port: 21)
. 2012-08-23 16:04:21.585 User name: user (Password: Yes, Key file: No)
. 2012-08-23 16:04:21.585 Tunnel: No
. 2012-08-23 16:04:21.585 Transfer Protocol: FTP
. 2012-08-23 16:04:21.585 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2012-08-23 16:04:21.586 Proxy: SOCKS5
. 2012-08-23 16:04:21.586 HostName: localhost (Port: 3121); Username: ; Passwd: No
. 2012-08-23 16:04:21.586 FTP: FTPS: None; Passive: Yes [Force IP: A]
. 2012-08-23 16:04:21.586 Local directory: C:\Users\korkmaz\Documents, Remote directory: /, Update: Yes, Cache: Yes
. 2012-08-23 16:04:21.586 Cache directory changes: Yes, Permanent: Yes
. 2012-08-23 16:04:21.586 DST mode: 1
. 2012-08-23 16:04:21.586 --------------------------------------------------------------------------
. 2012-08-23 16:04:21.666 Connecting to user.your-backup.de ...
. 2012-08-23 16:04:21.666 Connection failed.
* 2012-08-23 16:04:21.722 (EFatal) Connection failed.
* 2012-08-23 16:04:21.722 Connection failed.
In each of your logs, there's a different domain name. Are you manually editing the logs?
Anyway, there may be a firewall or something on your machine that blocks the debug version. Please try to disable the firewall for testing.
Tian
Issue resolved?
Is there a fix for this yet?
I seem to get the same issue on a server but can connect locally with winscp
After writing log on server found
. 2017-09-04 08:41:13.177 Connecting to Site ...
. 2017-09-04 08:41:13.177 Connected with Site, negotiating TLS connection...
. 2017-09-04 08:41:13.177 Disconnected from server
. 2017-09-04 08:41:13.177 Connection failed.
* 2017-09-04 08:41:14.114 (EFatal) Connection failed.
* 2017-09-04 08:41:14.114 Disconnected from server
* 2017-09-04 08:41:14.114 Connection failed.
Re: Issue resolved?
Can you connect with any other FTPS client? Start a new thread and post complete log files of WinSCP and the other FTPS client.
