Topic "transferOptions.FilePermissions question."
AJDValien
Hi all,
Not sure if this is the right forum or not. Been automating WinSCP using some Powershell scripts. But when I do an upload I get this error:
PS R:\PowerShellScripts> .\SFTPToPDCs.ps1
Beginning FTP Upload.
Upload of file '1208E.pjb' was successful, but error occurred while setting the
permissions and/or timestamp. If the problem persists, turn on 'Ignore permissio
n errors' option.
So looking around the documentation I stumbled on this:
http://winscp.net/eng/docs/library_filepermissions
and this to remove it via the GUI or command line - http://winscp.net/eng/docs/ui_transfer_custom#upload_options
So how would I implement this in my script? I looked at the PS examples but no go.
Would this work? (text in red)
$transferOptions.FilePermissions = $Null
The idea is to keep the permissions the same when I upload the files.
# Connect
      Write-Host "Beginning FTP Upload."
        # Upload files
        $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
      $transferResult = $session.PutFiles("R:\RESOURCES\Data\*", "/users/xfer/", $FALSE, $transferOptions)
Southbay
I'm having the exact same problem. I'm using WS_FTP as the destination server and I can get a single file uploaded but then it throws the exception. I attempted your TransferOptions.FilePermissions=$Null idea but no go for me. I really wish I could have gotten this to work, put a bit of time into this powershell script which wraps winscp.
AJDValien
Wow, surprised no one else has weighed in on this. For now I have to manually FTP (using FileZilla) instead of WinSCP since I can't override (or figure out the override) on the permissions to automate it. Sad
Please read documentation:
http://winscp.net/eng/docs/faq_not_owner
If that does not help, come back.
AJDValien
Just now getting back to this. Was able to test this tonight and PowerShell does not recognize the null option and throws this exception:
The term 'null' is not recognized as the name of a cmdlet, function, script file
, or operable program. Check the spelling of the name, or if a path was included
, verify that the path is correct and try again.
So back to the drawing board...
This is what I had in my PS script:
      $transferOptions.FilePermissions = null
      $transferOptions.PreserveTimestamp = false
Edit: Got it!
Had to use this for PowerShell to pick it up:
$transferOptions.FilePermissions = $null
$transferOptions.PreserveTimestamp = $false
Worked like a charm!
