Topic "Help using multiple masks in my script"
xmrkite
Hello, I just can't get masks to work from my script.
Here is my options file below:
option batch abort
open test
synchronize remote -filemask="|*.bak; *.zip; */abc/" "C:\Documents and Settings\test\Desktop\test" "/" -delete
So i want to transfer everything except the .bak, .zip files and skip the abc folder.
What am I doing wrong? This won't even complete with that in there. I am using winscp 4.x
There's no -filemask switch in 4.x. Please upgrade to 5.0.8 RC or use "option exclude <mask>" with 4.x
http://winscp.net/eng/docs/scriptcommand_get
http://winscp.net/eng/docs/scriptcommand_option
xmrkite
OK, I got it
Here is what worked (since I could not find this anywhere online)
option exclude *.bak;*.sql;test1*
This takes out all .bak and .sql files from the backup as well as the test1 folder.
-Thanks
