Topic "Files uploaded to FTP server dont appear on the server"
dwinn86
I have created a site in Visual Studio using VB.Net and ASP.Net that allows the upload and download of files to and from an FTP server via SFTP
I have produced the code, and my site allows a file to be uploaded via SFTP (WinSCP) but when I go on to the server, the files that I have uploaded do not appear to be there.
Here is my code:
If (mySession.Opened) Then
                'transferResult = session.PutFiles(FileUpload1.ToString, "/", True, transferOptions)
                transferResult = mySession.PutFiles(LocalPath, RemotePath, False, transferOptions)
                ' Throw on any error
                transferResult.Check()
            End If
Can anybody please advise on whyt his is happening?
Many thanks
Please set Session.SessionLogPath and attach a log file here.
dwinn86
I do not appear to be getting a log file come out at all.
Here is my code:
Protected Function ProcessFiles() As String
        Dim Path As String
        Dim LocalPath As String
        Dim RemotePath As String
        Path = "C:\WinSCP\WinSCP.exe"
        LocalPath = "C:\" + FileUpload1.FileName
        'RemotePath = "ftp://user:password@xx.x.xx.xx/In/"
        Try
            ' Setup session options
            MsgBox("Processing")
            With sessionOptions
                .Protocol = Protocol.Sftp
                .HostName = "xx.xx.xx.xx"
                .PortNumber = 22
                .UserName = "user"
                .Password = "password"
                .SshHostKey = "ssh-rsa xxxx xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
            End With
            'Set up the session
            'Using session As Session = New Session
            Dim mySession As New Session
                ' Connect
            mySession.ExecutablePath = Path
            mySession.Open(sessionOptions)
                ' Upload files
                ' Print results
            'Dim transfer As TransferEventArgs
            'For Each transfer In transferResult.Transfers
            'Console.WriteLine("Upload of {0} succeeded", transfer.FileName)
            'Console.Read()
            'Next
                mySession.SessionLogPath = "c:\WinSCP\log.log"
            End If
            'End Using
            Return 0
        Catch e As Exception
            Console.WriteLine("Error: {0}", e)
            Return 1
        End Try
    End Function
Any advice will be greatly apreciated.
You need to set that before calling Session.Open.
Otherwise, you should get an exception. Unless you are using an old version of WinSCP.
dwinn86
I put it to just before I open the session, and still not getting anything.
All I get is a page in IE after I try to upload the file, saying Internet explorer Cannot display the webpage.
I am using WinSCP 5.0.8 (Build 2438)
dwinn86
Ok, I have managed to get a log file to be produced.
Can somebody please tell me what I should be looking for within this file?
Many thanks
dwinn86
I managed to sort this out.
I was connecting successfully via SFTP, but the way my PutFiles() method was implemented was wrong.
Thank you for all your help.
