Topic "Secure Profil is it possible ?"
HatchFirst
Hi all,
The Automation script work fine with powershell and 2008R2 but,
I have a little problem with the [security Profil Winscp]
All of the information of my profil are :
HK_Current_user/Software/Martin Prikryl/WinSCP 2/Session/[My Session Name]
First HK_Current_User why not in HK_Users that's more secure
And if we want to secure a transaction with a SFTP Server, all of the connection information are in the current user, not good : ))
I can't write my profile connection in the script that's be worst.
So I see one solution :
Convert-to-SecureString my Script File, but i need to convert-from-SecureString for the execution
That's not very good but that's works fine (Ty Powershell)
My Question : If anyone knows how to bypass it i will very happy or just have an idee to make Winscp more secure for automation
Thanks to you by advance
Sorry for my poor english
You can store your configuration to an INI file instead of registry:
http://winscp.net/eng/docs/config
HatchFirst
Thanks, ill check it out.
