Topic "Uploading file to several servers fails"
Flanders
I have several servers that I frequently uploads a file to. I use a script like this:
option batch abort
open ftp://xxx:xxx@10.0.161.17 -timeout=30
put "C:\Documents and Settings\Updating tool\CSW0070.exe" /Update/*
open ftp://xxx:xxx@10.0.161.25 -timeout=30
open ftp://xxx:xxx@10.0.161.65 -timeout=30
My problem is that if when my script tries to connect to a server that is offline, then the script stops/fails, I get the following message: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
Is there any way to force WinSCP to skip the server that is offline and try the next server in the script?
Thanks!
Flanders
You should create a separate script for each server.
Or you can have just one script and pass a different hostnames as a parameter. For that see:
http://winscp.net/eng/docs/scripting#syntax
