Topic "special characters"
Adriatika
Firstly, thanks for the great work.
A point could be very interesting to fix : special characters are not supported in files name. Very annoying in some case. Or maybe I missed something ?
Your help will be very appreciated.
Can you please provide more details?
Adriatika
Thanks for your answer, prikryl.
By example, I've uploaded a file named :
"Film du 50me anniversaire"
In WinSCP, the file is renamed as :
"Film du 50ème anniversaire"
Same problem with pecial characters such as : and so on.
Hope it helps.
Possible trouble :
Maybe, if your computer is not compliant with these accented characteres you will not able to see them as I wrote in this message.
What version of WinSCP are you using? Have you tried 5.0.8 beta?
Have you read
http://winscp.net/eng/docs/faq_utf8 ?
Thanks a lot Martin.
I use version 4.3.9
Enabling UTF8 works!
I use version 4.3.9
What is your server? What protocol are you using?
