Topic ""Host is not communicating""
Nascimento
Hey, I used to log on this box before I upgraded to Windows 7 now after upgrading and installing the latest WinSCP version I get this error while trying.
I disabled the "Optimizing connection buffer size" and I still can't login.
Need help please.
Can you connect using any other SSH client?
No, that doesn't seem to work either...
Ok, can you connect from other machine?
Pascal Boulerie
(Thanks to prikryl for his advice about connecting from another machine.)
I just had wondered if if could be due to some firewall rule between the server and the WinSCP client ?
PS Actually, in my case, I got the message because I had typed a wrong port number in the WinSCP session panel... Now I can log in.
