Topic "Ports used when using FTP with Implicit SSL/TLS Implicit enc"
Johnson Thomas
My ftp with Implicit SSL/TLS Implicit encryption works only when ports in the range
10000 to 65000 are opened on the network alongwith port 990.
Please inform if any specific ports need to be opened for this to work.
Regards.
Johnson
Are you using passive or active FTP mode?
Johnson Thomas
Thanks for the reply.
We are using active mode.
Awaiting your revert.
Regards.
Johnson
With active mode, WinSCP opens local port, where the port number is autoassigned by an operating system.
I suggest you use passive mode.
