Topic "Copy double barrel file extentions"
DK
What does the command look like to copy a file with a double barrel extention ?
for example: "myFile20120828.xml.crderr"
Nothing special is needed to work with such files. Do you have any specific problem?
I use the following command "get *.*" assuming it will pick up all files, however it pulls all files except the ones mentioned above
*.* will indeed pick all files. I've just tested that.
Can you post your script and complete session log file?
