Topic "enable UTF-8 for remote server copy with .NET Assmbly in SCP"
sqlguy
We have downloaded the Portable executable & .NET assembly/COM library for version 5.0.7. Since I need to copy UTF-8 formatted files I was looking for a way to set UTF-8 filename encoding to "On" (as I do for the WinSCP executable, manually) via script. An example of code where I would like to set this is below.
(From MS 2005 SSIS dts package script)
With options
.Protocol = Protocol.Sftp
.HostName = Dts.Variables("My_WinSCP_Host").Value.ToString()
.UserName = Dts.Variables("My_WinSCP_User").Value.ToString()
.....etc
(looking at this point for an variable to set UTF-8 filename encoding to "On")
A sample solution would be something like .UTF8Encoding = "On" but the dll doesn't suggest a likely parameter.
Or is this possible using SCP?
For other non-UTF-8 copies this is working great!
Thanks in advance -
WinSCP does not support UTF-8 with SCP.
http://winscp.net/eng/docs/faq_utf8
yut
Look here, please. Does it work?
sqlguy
Thanks for the quick response and letting me know, Martin. This weekend I built an alternative approach and began testing it yesterday.
