Topic "Getting RemoteFileInfo.LastWriteTime is incorrect"
sramsay
I'm trying to manually synchronize files based on last modified time using C# code. However the LastWriteTime I'm getting from the remote file seems to be off by 1 hr. For example, the remote file was modified '12/8/2010 12:00:00 AM' and the local file was modified '12/7/2010 11:00:00 PM'. I've tried using SessionOptions.AddRawSettings to adjust it but it's not yielding any differences.
Here's my code:
public void Main()
try
// Setup session options
Protocol = Protocol.Ftp,
HostName = "ftp.x.org",
UserName = "anonymous",
Password = ""
sessionOptions.AddRawSettings("PreserveTime", "0");
sessionOptions.AddRawSettings("ConsiderDST", "1");
string remotePath = "/";
string localPath = "c:\\temp\\";
DateTime remoteWriteTime;
DateTime localWriteTime;
// Connect
session.Open(sessionOptions);
RemoteDirectoryInfo directory = session.ListDirectory(remotePath);
foreach (RemoteFileInfo fileInfo in directory.Files)
string remoteFilePath = remotePath + fileInfo.Name;
string localFilePath = localPath + fileInfo.Name;
// Check if the remote file exists locally
if (File.Exists(localFilePath))
remoteWriteTime = fileInfo.LastWriteTime;
localWriteTime = File.GetLastWriteTime(localFilePath);
if (remoteWriteTime > localWriteTime)
session.GetFiles(remoteFilePath, localFilePath, false, null).Check();
Any ideas?
I'm not sure what the problem is.
1) The remote file has actually a different timestamp than you get from RemoteFileInfo.LastWriteTime.
2) The file was uploaded by WinSCP and the remote timestamp does not match the timestamp of source local file.
sramsay
Thanks for the reply.
#1 is correct, #2 is not the case.
Have you seen this FAQ?
https://winscp.net/eng/docs/timestamp#windows
Does it help?
