Topic "Error Code 206: The filename or extension too long"
WinLinx
I have a WinSCP script which does file transfer automatically to the remote Linux machine.
I am facing Error Code: 206 saying The FileName or extension is too long.
How shall I fix it?
Please attach a full log file showing the problem.
To generate log file, use /log=path_to_log_file command-line argument. Submit the log with your post as an attachment. Note that passwords and passphrases not stored in the log. You may want to remove other data you consider sensitive though, such as host names, IP addresses, account names or file names (unless they are relevant to the problem). If you do not want to post the log publicly, you may email it to me. You will find my address (if you log in) in my forum profile. Please include link back to this topic in your email. Also note in this topic that you have emailed the log.
