Topic "Installing WinSCP, prevent Windows to Shutdown?"
akuzayah
Hello ,
i am new to using WinSCP ,
i have a problem after installing WinSCP on my Windows PC.
After i installed WinSCP ver 4.3.9 on my PC it's prevent my windows XP Profesional to shutdown, even when WinSCP not in use. I have the same problem in every window xp i installed winSCP.
I had to force shutdown (by typing shutdown -s -f in terminal or by pressing the physical shutdown button on my PC) to turn off my PC after installing winSCP.
why does this can be happen?
thx
Can you uninstall WinSCP to confirm it's related?
akuzayah
Yups... It 's related, after i uninstal the program or restored windows to previous stat before install winscp, i can shutdown the pc normaly
Can you do custom installation and unselect the "drag & drop shell extension"?
