Topic "Downloaded file with 0kb"
Captain7
My script is trying to get all the files from the remote server and then remove them. The file "PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001" seems to be downloaded to local folder but it has file size of 0kb and the file "PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3" did not get downloaded. This problem is intermittent and I have no idea what is wrong. I hope you can help me by reviewing the log file. Thanks very much!!
. 2012-09-05 11:30:26.348 --------------------------------------------------------------------------
. 2012-09-05 11:30:26.350 WinSCP Version 4.3.8 (Build 1771) (OS 6.0.6002 Service Pack 2)
. 2012-09-05 11:30:26.350 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2012-09-05 11:30:26.351 Local account: xxxx\xxx
. 2012-09-05 11:30:26.351 Login time: Wednesday, September 05, 2012 11:30:26 AM
. 2012-09-05 11:30:26.351 --------------------------------------------------------------------------
. 2012-09-05 11:30:26.351 Session name: xxxxxxx (Stored session)
. 2012-09-05 11:30:26.351 Host name: xxx.xx.xxx.xxx (Port: xxxx)
. 2012-09-05 11:30:26.351 User name: xxxxxxx (Password: Yes, Key file: No)
. 2012-09-05 11:30:26.351 Tunnel: No
. 2012-09-05 11:30:26.351 Transfer Protocol: FTP
. 2012-09-05 11:30:26.351 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2012-09-05 11:30:26.351 Proxy: none
. 2012-09-05 11:30:26.351 FTP: FTPS: None; Passive: Yes [Force IP: No]
. 2012-09-05 11:30:26.351 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2012-09-05 11:30:26.351 Cache directory changes: Yes, Permanent: Yes
. 2012-09-05 11:30:26.351 DST mode: 1
. 2012-09-05 11:30:26.374 Connecting to xxx.xx.xxx.xxx:xxxx ...
. 2012-09-05 11:30:26.376 Connected with xxx.xx.xxx.xxx:xxxx. Waiting for welcome message...
. 2012-09-05 11:30:26.377 --------------------------------------------------------------------------
. 2012-09-05 11:30:26.377 WinSCP Version 4.3.8 (Build 1771) (OS 6.0.6002 Service Pack 2)
. 2012-09-05 11:30:26.377 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2012-09-05 11:30:26.378 Local account: xxxx\xxx
. 2012-09-05 11:30:26.378 Login time: Wednesday, September 05, 2012 11:30:26 AM
. 2012-09-05 11:30:26.378 --------------------------------------------------------------------------
. 2012-09-05 11:30:26.378 Session name: xxxxxxx (Stored session)
. 2012-09-05 11:30:26.378 Host name: xxx.xx.xxx.xxx (Port: xxxx)
. 2012-09-05 11:30:26.378 User name: xxxxxxx (Password: Yes, Key file: No)
. 2012-09-05 11:30:26.378 Tunnel: No
. 2012-09-05 11:30:26.378 Transfer Protocol: FTP
. 2012-09-05 11:30:26.378 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2012-09-05 11:30:26.378 Proxy: none
. 2012-09-05 11:30:26.378 FTP: FTPS: None; Passive: Yes [Force IP: No]
. 2012-09-05 11:30:26.378 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2012-09-05 11:30:26.378 Cache directory changes: Yes, Permanent: Yes
. 2012-09-05 11:30:26.378 DST mode: 1
. 2012-09-05 11:30:26.380 Connecting to xxx.xx.xxx.xxx:xxxx ...
< 2012-09-05 11:30:26.380 220 Microsoft FTP Service
> 2012-09-05 11:30:26.381 USER xxxxxxx
. 2012-09-05 11:30:26.387 Connected with xxx.xx.xxx.xxx:xxxx. Waiting for welcome message...
< 2012-09-05 11:30:26.387 331 Password required for xxxxxxx.
> 2012-09-05 11:30:26.387 PASS ****************
< 2012-09-05 11:30:26.392 220 Microsoft FTP Service
> 2012-09-05 11:30:26.392 USER xxxxxxx
< 2012-09-05 11:30:26.392 230 User logged in.
> 2012-09-05 11:30:26.393 SYST
< 2012-09-05 11:30:26.397 331 Password required for xxxxxxx.
> 2012-09-05 11:30:26.397 PASS ****************.397 215 Windows_NT
> 2012-09-05 11:30:26.397 FEAT
< 2012-09-05 11:30:26.405 230 User logged in.
> 2012-09-05 11:30:26.405 SYST
< 2012-09-05 11:30:26.405 211-Extended features supported:
< 2012-09-05 11:30:26.405 LANG EN*
< 2012-09-05 11:30:26.405 UTF8
< 2012-09-05 11:30:26.405 AUTH TLS;TLS-C;SSL;TLS-P;
< 2012-09-05 11:30:26.405 PBSZ
< 2012-09-05 11:30:26.405 PROT C;P;
< 2012-09-05 11:30:26.405 CCC
< 2012-09-05 11:30:26.405 HOST
< 2012-09-05 11:30:26.405 SIZE
< 2012-09-05 11:30:26.405 MDTM
< 2012-09-05 11:30:26.405 REST STREAM
< 2012-09-05 11:30:26.405 211 END
> 2012-09-05 11:30:26.405 OPTS UTF8 ON
< 2012-09-05 11:30:26.410 215 Windows_NT
> 2012-09-05 11:30:26.410 FEAT
< 2012-09-05 11:30:26.411 200 OPTS UTF8 command successful - UTF8 encoding now ON.
. 2012-09-05 11:30:26.411 Connected
. 2012-09-05 11:30:26.411 --------------------------------------------------------------------------
. 2012-09-05 11:30:26.412 Using FTP protocol.
. 2012-09-05 11:30:26.412 Doing startup conversation with host.
> 2012-09-05 11:30:26.412 PWD
< 2012-09-05 11:30:26.415 211-Extended features supported:
< 2012-09-05 11:30:26.415 LANG EN*
< 2012-09-05 11:30:26.415 UTF8
< 2012-09-05 11:30:26.415 AUTH TLS;TLS-C;SSL;TLS-P;
< 2012-09-05 11:30:26.415 PBSZ
< 2012-09-05 11:30:26.415 PROT C;P;
< 2012-09-05 11:30:26.416 CCC
< 2012-09-05 11:30:26.416 HOST
< 2012-09-05 11:30:26.416 SIZE
< 2012-09-05 11:30:26.416 MDTM
< 2012-09-05 11:30:26.416 REST STREAM
< 2012-09-05 11:30:26.416 211 END
> 2012-09-05 11:30:26.416 OPTS UTF8 ON
< 2012-09-05 11:30:26.417 257 "/" is current directory.
. 2012-09-05 11:30:26.417 Getting current directory name.
. 2012-09-05 11:30:26.417 Startup conversation with host finished.
< 2012-09-05 11:30:26.417 Script: Active session: [1] eSolutions
> 2012-09-05 11:30:26.418 Script: lcd C:\Batch\PD\FTP\Files
< 2012-09-05 11:30:26.418 Script: C:\Batch\PD\FTP\Files
> 2012-09-05 11:30:26.418 Script: get -delete *.
. 2012-09-05 11:30:26.419 Retrieving directory listing...
> 2012-09-05 11:30:26.419 TYPE A
< 2012-09-05 11:30:26.420 200 OPTS UTF8 command successful - UTF8 encoding now ON.
. 2012-09-05 11:30:26.420 Connected
. 2012-09-05 11:30:26.420 --------------------------------------------------------------------------
. 2012-09-05 11:30:26.420 Using FTP protocol.
. 2012-09-05 11:30:26.421 Doing startup conversation with host.
> 2012-09-05 11:30:26.421 PWD
< 2012-09-05 11:30:26.424 200 Type set to A.
> 2012-09-05 11:30:26.425 PASV
< 2012-09-05 11:30:26.425 257 "/" is current directory.
. 2012-09-05 11:30:26.426 Getting current directory name.
. 2012-09-05 11:30:26.426 Startup conversation with host finished.
< 2012-09-05 11:30:26.426 Script: Active session: [1] eSolutions
> 2012-09-05 11:30:26.426 Script: lcd C:\Batch\PD\FTP\Files
< 2012-09-05 11:30:26.426 Script: C:\Batch\PD\FTP\Files
> 2012-09-05 11:30:26.426 Script: get -delete *.
. 2012-09-05 11:30:26.427 Retrieving directory listing...
> 2012-09-05 11:30:26.427 TYPE A
< 2012-09-05 11:30:26.430 227 Entering Passive Mode (216,16,234,157,193,94).
> 2012-09-05 11:30:26.431 LIST -a
< 2012-09-05 11:30:26.431 200 Type set to A.
> 2012-09-05 11:30:26.432 PASV
< 2012-09-05 11:30:26.435 150 Opening ASCII mode data connection.
< 2012-09-05 11:30:26.437 227 Entering Passive Mode (216,16,234,157,193,95).
> 2012-09-05 11:30:26.437 LIST -a
< 2012-09-05 11:30:26.441 226 Transfer complete.
. 2012-09-05 11:30:26.441 150 Opening ASCII mode data connection.
Directory listing successful
< 2012-09-05 11:30:26.446 226 Transfer complete.
. 2012-09-05 11:30:26.447 Directory listing successful
. 2012-09-05 11:30:26.450 .ile: "/PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3"
2012-09-05 11:30:26.450 File: "/PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3"
. 2012-09-05 11:30:26.450 Copying "/PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3" to local directory started.
. 2012-09-05 11:30:26.450 2012-09-05 11:30:26.450 cted.
Binary transfer mode selected.
..2012-09-05 11:30:26.451 Starting download of /PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3 2012-09-05 11:30:26.451 Starting download of /PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3
>>2012-09-05 11:30:26.454 2012-09-05 11:30:26.454 TYPE I
< 2012-09-05 11:30:26.460 200 Type set to I.<
> 2012-09-05 11:30:26.460 PASV
< 2012-09-05 11:30:26.466 227 Entering Passive Mode (216,16,234,157,193,96).
< 2012-09-05 11:30:26.466 227 Entering Passive Mode (216,16,234,157,193,97).
> 2012-09-05 11:30:26.466 RETR PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3
< 2012-09-05 11:30:26.471 150 Opening BINARY mode data connection..
2012-09-05 11:30:26.471 Can't open file 'C:\Batch\PD\FTP\Files\PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3'.
. 2012-09-05 11:30:26.472 Copying files from remote side failed.
* 2012-09-05 11:30:26.478 (ExtException) Can't open file 'C:\Batch\PD\FTP\Files\PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3'.
* 2012-09-05 11:30:26.478 Copying files from remote side failed.
* 2012-09-05 11:30:26.478 Entering Passive Mode (216,16,234,157,193,97).
. 2012-09-05 11:30:26.478 Asking user:
. 2012-09-05 11:30:26.478 Error transferring file '/PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3'. ("Can't open file 'C:\Batch\PD\FTP\Files\PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3'.","Copying files from remote side failed.","Entering Passive Mode (216,16,234,157,193,97).")
* 2012-09-05 11:30:26.487 (EScpSkipFile) Error transferring file '/PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3'.
* 2012-09-05 11:30:26.487 Can't open file 'C:\Batch\PD\FTP\Files\PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3'.
* 2012-09-05 11:30:26.487 Copying files from remote side failed.
* 2012-09-05 11:30:26.487 Entering Passive Mode (216,16,234,157,193,97).
. 2012-09-05 11:30:26.487 File: "/PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001"
. 2012-09-05 11:30:26.487 Copying "/PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001" to local directory started.
. 2012-09-05 11:30:26.487 Binary transfer mode selected.
. 2012-09-05 11:30:26.488 Starting download of /PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001
> 2012-09-05 11:30:26.488 TYPE I
< 2012-09-05 11:30:26.494 200 Type set to I.
> 2012-09-05 11:30:26.494 PASV
< 2012-09-05 11:30:26.500 227 Entering Passive Mode (216,16,234,157,193,98).
> 2012-09-05 11:30:26.501 RETR PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001
< 2012-09-05 11:30:26.507 150 Opening BINARY mode data connection.
< 2012-09-05 11:30:26.634 226 Transfer complete.
. 2012-09-05 11:30:26.634 Download successful
. 2012-09-05 11:30:26.646 Deleting file "/PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001".
> 2012-09-05 11:30:26.646 DELE /PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001
< 2012-09-05 11:30:26.648 226 Transfer complete.
. 2012-09-05 11:30:26.648 Download successful
. 2012-09-05 11:30:26.648 Deleting file "/PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3".
> 2012-09-05 11:30:26.648 DELE /PDAcc_0a2eee8a-9721-4bd6-988a-2cfca83190c3
< 2012-09-05 11:30:26.650 250 DELE command successful.
> 2012-09-05 11:30:26.651 Script: close
. 2012-09-05 11:30:26.652 Disconnected from server
< 2012-09-05 11:30:26.653 250 DELE command successful.
. 2012-09-05 11:30:26.653 File: "/PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001"
. 2012-09-05 11:30:26.653 Copying "/PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001" to local directory started.
. 2012-09-05 11:30:26.654 Binary transfer mode selected.
. 2012-09-05 11:30:26.654 Starting download of /PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001
> 2012-09-05 11:30:26.654 TYPE I
< 2012-09-05 11:30:26.659 200 Type set to I.
> 2012-09-05 11:30:26.660 PASV
< 2012-09-05 11:30:26.665 227 Entering Passive Mode (216,16,234,157,193,99).
> 2012-09-05 11:30:26.666 RETR PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001
< 2012-09-05 11:30:26.671 550 The system cannot find the file specified.
. 2012-09-05 11:30:26.671 Copying files from remote side failed.
* 2012-09-05 11:30:26.671 (ExtException) Copying files from remote side failed.
* 2012-09-05 11:30:26.671 The system cannot find the file specified.
. 2012-09-05 11:30:26.671 Asking user:
. 2012-09-05 11:30:26.671 Error transferring file '/PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001'. ("Copying files from remote side failed.","The system cannot find the file specified. ")
* 2012-09-05 11:30:26.672 (EScpSkipFile) Error transferring file '/PDReq_0a2eee8a-9721-4bd6-988a-2cfca83190c3_2012-09-05-1053-00001'.
* 2012-09-05 11:30:26.672 Copying files from remote side failed.
* 2012-09-05 11:30:26.672 The system cannot find the file specified.
> 2012-09-05 11:30:26.672 Script: close
. 2012-09-05 11:30:26.672 Disconnected from server
Seeing the log file, it looks like there are two instances of WinSCP running in parallel.
Captain7
I use Windows's Task Scheduler to run the script every 5 minutes and there is only one task set up there. I also have the option "Do not start a new instance" set in the Task Scheduler. I don't think each run will take more than 5 seconds as the files being downloaded are only a few kilobytes and only a few files sitting in the remote server. I'll try to remove the task from the Task Scheduler and create it again.
