Topic "SFTPv4 Not Supported Error"
iceparrot
Using WinSCP 3.56
Server is VShell 2.02
When I connect to my SSH server, I get a exit 0 error.
Upon looking at the server logs:
16:21:16,conn,00022: Session channel open request accepted.
16:21:16,sftp,00022: Unsupported SFTP protocol version 4
16:21:16,conn,00022: Session channel has been closed (pid: none).
16:21:16,sftp,00022: Sftp subsystem terminated.
16:21:16,conn,00022: Connection closed.
My understanding from reading the forum posts is that WinSCP should run version 3 if the server will not support version 4. Is there a way to force WinSCP to run a certain version?
I'm using VShell (the latest version) and I have no problem. The version I use supports SFTP4.
Anyway, it is the server who decides what version of SFTP is going to be used. The client only sends the highest supported SFTP version and the server chooses the either it (if it supports it) or any lower. So I do not understand at all what does the error means.
Try to upgrade to the latest VShell.
You may also try WinSCP 3.1, which supports only SFTP3.
iceparrot
The newest VShell (2.2.5) works fine with WinSCP. Thanks for the advice.
I did try another SFTP program before I switched to the newer Vshell, and VShell sent it the right version of SFTP and it connected fine, thus I'm not sure if it was a small bug in Vshell or WinSCP
