Topic "UTF-8 characters not showing up properly"
eiji-gravion
I noticed a few UTF-8 characters that show up as a question mark (?), and a few that if in a folder name, display correctly, but don't allow you go access them.
Examples:
Folders with ⁄⁄ display correctly, but don't allow you to access them.
Folders/files with ♥ ✴ show up as a question mark, and don't allow you to access them.
I'm sure there are other examples, but these are the ones I've noticed so far.
eiji-gravion
My apologies, I forgot to mention that I'm using the latest version of WinSCP (4.3.9), and I've tried using FTP and FTPES for the protocol.
Thanks again.
Can you try the latest beta version? 5.0.9 beta.
5.0.9 RC works fine.
srynoname
I am on 5.1.0.2625, using SFTP, the german umlaut "" isn't displayed correctly. I guess winscp uses some external library for ssh / ftps, I'd like to note that when using putty to ssh into the machine, I have to change the encoding to UTF-8 for it to properly display the german "". Maybe it's the same problem here? Besides that, great software!
Have you tried to force UTF-8?
http://winscp.net/eng/docs/ui_login_environment
srynoname
I don't know why, but even without modifying this setting it's now suddenly displayed correctly Wink But I will remember this setting, if I have this problem again Wink
JoKalliauer
I have the same Problem: with (Ä Ö Ü ä ö ü)
In WinSCP 5.5.2:
If i enable UTF-8: (� � � � � �)
If i disable UTF-8: (? ™ „ +– )
In WinSCP 4.3.2:
If i enable UTF-8: Error: error decoding utf-8 string
Ps. (I have a german version, so I don't know the exact englisch errormessage)
In WinSCP 5.5.2:
In WinSCP 4.3.2:
JoKalliauer
prikryl wrote:
Thank's for linking how to enable Logging. (I am a newbee in WinSCP, I don't know much about WinSCP.)
But I think the log won't help you, cause there is no message.
It just decodes the letters wrong. (Don't know how to write it right in English.)
best regards
Johannes
joka@bizfs1.htu.tuwien.ac.at.xml.log (177 Bytes) [Download]
Description: <?xml version="1.0" encoding="UTF-8"?>
<session xmlns="http://winscp.net/schema/session/1.0" name="joka@bizfs1.htu.tuwien.ac.at" start="2014-03-24T17:09:53.734Z">
</session>
This is XML log. I need a session log.
JoKalliauer
I enabled the Session log in http://winscp.net/eng/docs/ui_pref_logging
The file should be atteached.
joka@bizfs1.htu.tuwien.ac.at.log (8.01 KB) [Download]
Description: . 2014-03-27 13:51:15.325 Closing connection.
. 2014-03-27 13:51:15.325 Sending special code: 12
. 2014-03-27 13:51:15.329 Sent EOF message
. 2014-03-27 13:51:20.383 --------------------------------------------------------------------------
. 2014-03-27 1
Thanks. Can you please enable Debug 2-level logging?
Also, how was those files created?
JoKalliauer
I made this settings:
I made them with WinSCP
Version 5.5.2 (Build 4130)
(I don't understand the Question.)
OK, that's a different problem then. I need to see a log showing how you upload the file. Ideally to an empty folder.
JoKalliauer
Thank's for helping, our admin solved the Problem. Smile
LaytXP
How did he solve it? I have the same problem. If I force UTF-8 I can't download the files from the server. The program returns the error message, that the file doesn't exist.
Can anyone provide me a tests account on a server? Or at least help me with testing a possible workaround?
LaytXP
I would be glad to help you. But I can only try a workaround, as I can't give you a test-account.
Thanks. Can you please send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
Dietrich
I followed this discussion and don't see the solution.???? What can I do. In the newest version I don't find the possibility to force utf-8.
It is still there:
