Topic "GetPeerName Failed in WinSCP GUI"
sorcer1
I get the error "Error listing directory : GetPeerName failed when i connect to a FTP with a proxy.
I have no errors if i remove the proxy.
This is the session log :
. 2012-09-10 10:30:44.918 --------------------------------------------------------------------------
. 2012-09-10 10:30:44.918 WinSCP Version 5.0.8 (Build 2438) (OS 6.1.7601 Service Pack 1)
. 2012-09-10 10:30:44.918 Configuration: C:\Tools\winscp508\WinSCP.ini
. 2012-09-10 10:30:44.918 Local account: AD\drm
. 2012-09-10 10:30:44.918 Login time: lundi 10 septembre 2012 10:30:44
. 2012-09-10 10:30:44.918 Session name: user@aka.com (Ad-Hoc session)
. 2012-09-10 10:30:44.918 Host name: aka.com (Port: 21)
. 2012-09-10 10:30:44.918 User name: user (Password: Yes, Key file: No)
. 2012-09-10 10:30:44.918 Tunnel: No
. 2012-09-10 10:30:44.918 Transfer Protocol: FTP
. 2012-09-10 10:30:44.918 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2012-09-10 10:30:44.918 Proxy: HTTP
. 2012-09-10 10:30:44.918 HostName: myproxy.com (Port: 3128); Username: ; Passwd: No
. 2012-09-10 10:30:44.918 FTP: FTPS: None; Passive: Yes [Force IP: A]
. 2012-09-10 10:30:44.918 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2012-09-10 10:30:44.918 Cache directory changes: Yes, Permanent: Yes
. 2012-09-10 10:30:44.918 DST mode: 1
. 2012-09-10 10:30:44.980 Connecting to aka.com ...
. 2012-09-10 10:30:45.105 Connected with aka.com. Waiting for welcome message...
< 2012-09-10 10:30:45.246 220 Welcome
> 2012-09-10 10:30:45.246 USER user
< 2012-09-10 10:30:45.386 331 Password required for user.
> 2012-09-10 10:30:45.386 PASS ********
< 2012-09-10 10:30:45.776 230 User user logged in.
> 2012-09-10 10:30:45.776 SYST
< 2012-09-10 10:30:45.792 215 UNIX Type: L8
> 2012-09-10 10:30:45.792 FEAT
< 2012-09-10 10:30:45.792 211-Features:
< 2012-09-10 10:30:45.792  MDTM
< 2012-09-10 10:30:45.792  REST STREAM
< 2012-09-10 10:30:45.792  SIZE
< 2012-09-10 10:30:45.792  AUTH TLS
< 2012-09-10 10:30:45.792  PBSZ
< 2012-09-10 10:30:45.807  PROT
< 2012-09-10 10:30:45.807 211 End
. 2012-09-10 10:30:45.854 Connected
. 2012-09-10 10:30:45.854 --------------------------------------------------------------------------
. 2012-09-10 10:30:45.854 Using FTP protocol.
. 2012-09-10 10:30:45.854 Doing startup conversation with host.
> 2012-09-10 10:30:45.916 PWD
< 2012-09-10 10:30:45.916 257 "/39311/ROOT" is current directory.
. 2012-09-10 10:30:45.979 Getting current directory name.
. 2012-09-10 10:30:46.166 Retrieving directory listing...
> 2012-09-10 10:30:46.166 TYPE A
< 2012-09-10 10:30:46.166 200 Type set to A
> 2012-09-10 10:30:46.166 PASV
< 2012-09-10 10:30:46.166 227 Entering Passive Mode (2,21,254,26,161,218).
. 2012-09-10 10:30:46.166 GetPeerName failed
. 2012-09-10 10:30:46.166 Could not retrieve directory listing
. 2012-09-10 10:30:46.228 Retrieving directory listing...
> 2012-09-10 10:30:46.228 TYPE A
< 2012-09-10 10:30:46.228 200 Type set to A
> 2012-09-10 10:30:46.228 PASV
< 2012-09-10 10:30:46.228 227 Entering Passive Mode (2,21,254,26,216,144).
. 2012-09-10 10:30:46.228 GetPeerName failed
. 2012-09-10 10:30:46.228 Could not retrieve directory listing
* 2012-09-10 10:30:46.353 (ECommand) Error listing directory '/39311/ROOT'.
* 2012-09-10 10:30:46.353 GetPeerName failed
* 2012-09-10 10:30:46.353 Could not retrieve directory listing
* 2012-09-10 10:30:46.353 Entering Passive Mode (2,21,254,26,216,144).
> 2012-09-10 10:30:50.191 TYPE A
< 2012-09-10 10:30:50.191 200 Type set to A
. 2012-09-10 10:31:03.498 Startup conversation with host finished.
> 2012-09-10 10:31:16.774 TYPE A
< 2012-09-10 10:31:16.774 200 Type set to A
> 2012-09-10 10:31:19.817 TYPE A
< 2012-09-10 10:31:19.817 200 Type set to A
Please try 5.0.9 beta.
