Topic "Preserve timestamp isn't preserving it"
Swifty
I've just moved (hurriedly) from XP to Win7 and then installed 4.3.9 (Build 1817). I got no chance to capture my settings, so I'm starting from scratch.
I just transferred a file , from local to remote as follows:
Local file: xxxx.html size:5,466 Changed:09/09/2012 13:16:16
Original remote file: xxxx.html size:5,390 Changed:09/09/2012 10:14
New remote file (according to WinSCP): xxxx.html size:5,390 Changed:14/09/2012 07:02
There's a couple of odd things going on:
1. The indicated size hasn't changed. The file itself is now 5,466 bytes, as expected
2. The "Changed" timestamp shows the time/date of the transfer, but I have "Preserve Timestamp" in effect
Are these easily fixed?
Does this explain it?
http://winscp.net/eng/docs/faq_transfer_size_change
Please attach a full log file showing the problem.
prikryl wrote:
Yes, it's a CRLF/LF effect on a TEXT transfer.
I'll do this sometime soon.
