Topic "Install 5.0.8 or 5.0.9 over 5.0.7, cleans all previosly conf"
mxsimpson
I have 5.0.7 installed and when I install versions 5.0.8 or 5.0.9, the program cleans all my configuration. The configuration is setted to a .INI file, and when I install a new version, the file still exist but seens that the program is not using it.
OS: Win 7.
Possibly related to:
http://winscp.net/tracker/show_bug.cgi?id=874
Where is your INI file located?
Were you using 4.x previously?
Now I'm using 5.0.7 and the INI file is in the Program Files folder.
I've tried update to 5.1 and the same problem occurs.
mxsimpson
I move de INI file from the program files foder to "C:\Users\USER\AppData\Local\VirtualStore\Program Files\WinSCP" and then winscp found it!
Why the location of the INI file changed?
May I suggest a Import button from INI file, like the button Export that already exist?
Thanks!
