Topic "Host does not exist..HELP"
The following is the connection parameters within WINSCP.INI file: (it works fine)
[Sessions\shared@trilliant@www.trilliantnetworks.com]
HostName=www.trilliantnetworks.com
PortNumber=21
UserName=shared@trilliant
FSProtocol=5
Password=A35C6E5C2F343D2E39381C282E353030353D32282B2B2B72282E353030353D32283239282B332E372F723F33316E3E3A2E6D6F32382F[/color]
and the following is the script I am attempting to use to connect...
option batch on
open shared@trilliant@www.trilliantnetworks.com
option transfer binary
put \\Eeaugs1nas01\AMI\AMI General\AMI Head End\analyze\Data Dump\Query_dumps\BRIDGEDETAILS_2012-09-16_1100.txt BRIDGEDETAILS_2012-09-16_1100.txt
Close
Exit
Why can't I connect?
Mike
Can anyone help?
I could connect to your server right away. So it is probably a local issue on your machine.
Anyway, you should really change your password now!
