Topic "WinSCP 5.0.9 cannot script FTP PUT file when using SOCKS"
pabesco325
Hi
I am using WinSCP 5.0.9.2578 on Windows Server 2008 (not RC2).
Here is what I am trying to do:
Run WinSCP under a batch script to upload a file using FTP through a SOCKS connection (using Vidalia for the proxy). For some reason I am able to log in but I get a timeout error when I try to PUT the file. I tried SOCKS4 and SOCKS5
Command invocation:
"C:\Program Files (x86)\WinSCP\winscp.exe" /passive=on /log=log.txt /xmllog=log.xml /console /script=upload.txt
Batch script "upload.txt":
option batch abort
open ftp://[USER]:[PASS]@[HOST]:[PORT] -rawsettings ProxyMethod=2 ProxyHost=127.0.0.1 ProxyPort=9050
lcd ./installers
cd /public_html/install
put -transfer=binary installer_505e2c64d7db8.php install.php
close
quit
Log file showing the timeout loop:
. 2012-09-23 05:58:26.513 --------------------------------------------------------------------------
. 2012-09-23 05:58:26.514 WinSCP Version 5.0.9 (Build 2578) (OS 6.0.6001 Service Pack 1)
. 2012-09-23 05:58:26.515 Configuration: C:\Program Files (x86)\WinSCP\WinSCP.ini
. 2012-09-23 05:58:26.515 Local account: WORKGROUP\VPS8000$
. 2012-09-23 05:58:26.515 Working directory: C:\wamp\www\panel
. 2012-09-23 05:58:26.515 Command-line: "C:\Program Files (x86)\WinSCP\winscp.exe"  /passive=on /log=log.txt /xmllog=log.xml /console /script=upload.txt
. 2012-09-23 05:58:26.515 Login time: Sunday, September 23, 2012 5:58:26 AM
. 2012-09-23 05:58:26.515 --------------------------------------------------------------------------
. 2012-09-23 05:58:26.515 Session name: [USER]@[HOST] (Ad-Hoc session)
. 2012-09-23 05:58:26.515 Host name: [HOST] (Port: 21)
. 2012-09-23 05:58:26.516 User name: [USER] (Password: Yes, Key file: No)
. 2012-09-23 05:58:26.516 Tunnel: No
. 2012-09-23 05:58:26.516 Transfer Protocol: FTP
. 2012-09-23 05:58:26.516 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2012-09-23 05:58:26.516 Proxy: SOCKS5
. 2012-09-23 05:58:26.516 HostName: 127.0.0.1 (Port: 9050); Username: ; Passwd: No
. 2012-09-23 05:58:26.516 FTP: FTPS: None; Passive: Yes [Force IP: A]
. 2012-09-23 05:58:26.516 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2012-09-23 05:58:26.516 Cache directory changes: Yes, Permanent: Yes
. 2012-09-23 05:58:26.516 DST mode: 1
. 2012-09-23 05:58:26.516 --------------------------------------------------------------------------
. 2012-09-23 05:58:26.520 Connecting to [HOST] ...
. 2012-09-23 05:58:27.946 Connected with [HOST]. Waiting for welcome message...
< 2012-09-23 05:58:28.328 220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
< 2012-09-23 05:58:28.328 220-You are user number 1 of 50 allowed.
< 2012-09-23 05:58:28.328 220-Local time is now 05:58. Server port: 21.
< 2012-09-23 05:58:28.328 220-This is a private system - No anonymous login
< 2012-09-23 05:58:28.328 220 You will be disconnected after 15 minutes of inactivity.
> 2012-09-23 05:58:28.328 USER [USER]
< 2012-09-23 05:58:30.492 331 User [USER] OK. Password required
> 2012-09-23 05:58:30.492 PASS **********
< 2012-09-23 05:58:32.210 230 OK. Current restricted directory is /
> 2012-09-23 05:58:32.210 SYST
< 2012-09-23 05:58:33.121 215 UNIX Type: L8
> 2012-09-23 05:58:33.122 FEAT
< 2012-09-23 05:58:34.140 211-Extensions supported:
< 2012-09-23 05:58:34.140  EPRT
< 2012-09-23 05:58:34.140  IDLE
< 2012-09-23 05:58:34.140  MDTM
< 2012-09-23 05:58:34.140  SIZE
< 2012-09-23 05:58:34.140  MFMT
< 2012-09-23 05:58:34.140  REST STREAM
< 2012-09-23 05:58:34.140  MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
< 2012-09-23 05:58:34.140  MLSD
< 2012-09-23 05:58:34.140  AUTH TLS
< 2012-09-23 05:58:34.140  PBSZ
< 2012-09-23 05:58:34.140  PROT
< 2012-09-23 05:58:34.140  ESTA
< 2012-09-23 05:58:34.140  PASV
< 2012-09-23 05:58:34.140  EPSV
< 2012-09-23 05:58:34.140  SPSV
< 2012-09-23 05:58:34.140  ESTP
< 2012-09-23 05:58:34.140 211 End.
. 2012-09-23 05:58:34.140 Connected
. 2012-09-23 05:58:34.140 --------------------------------------------------------------------------
. 2012-09-23 05:58:34.140 Using FTP protocol.
. 2012-09-23 05:58:34.143 Doing startup conversation with host.
> 2012-09-23 05:58:34.143 PWD
< 2012-09-23 05:58:35.349 257 "/" is your current location
. 2012-09-23 05:58:35.350 Getting current directory name.
. 2012-09-23 05:58:35.350 Startup conversation with host finished.
< 2012-09-23 05:58:35.350 Script: Active session: [1] [USER]@[HOST]
> 2012-09-23 05:58:35.350 Script: lcd ./installers
< 2012-09-23 05:58:35.350 Script: C:\wamp\www\panel\installers
> 2012-09-23 05:58:35.351 Script: cd /public_html/install
. 2012-09-23 05:58:35.351 Cached directory change via "/public_html/install" to "/public_html/install".
. 2012-09-23 05:58:35.351 Getting current directory name.
< 2012-09-23 05:58:35.351 Script: /public_html/install
> 2012-09-23 05:58:35.351 Script: put -transfer=binary installer_505e2c64d7db8.php install.php
. 2012-09-23 05:58:35.352 Copying 1 files/directories to remote directory "/public_html/install"
. 2012-09-23 05:58:35.352   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask: install.php
. 2012-09-23 05:58:35.352   TM: B; ClAr: No; CPS: 0; InclM:
. 2012-09-23 05:58:35.352   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2012-09-23 05:58:35.352 File: "installer_505e2c64d7db8.php"
. 2012-09-23 05:58:35.352 Copying "installer_505e2c64d7db8.php" to remote directory started.
. 2012-09-23 05:58:35.353 Binary transfer mode selected.
. 2012-09-23 05:58:35.353 Starting upload of installer_505e2c64d7db8.php
> 2012-09-23 05:58:35.353 CWD /public_html/install/
< 2012-09-23 05:58:36.615 250 OK. Current directory is /public_html/install
> 2012-09-23 05:58:36.615 PWD
< 2012-09-23 05:58:37.449 257 "/public_html/install" is your current location
> 2012-09-23 05:58:37.449 TYPE A
< 2012-09-23 05:58:38.760 200 TYPE is now ASCII
> 2012-09-23 05:58:38.761 PASV
< 2012-09-23 05:58:39.789 227 Entering Passive Mode (111,90,133,160,154,254)
. 2012-09-23 05:58:39.790 Error retrieving server address
> 2012-09-23 05:58:39.790 MLSD
. 2012-09-23 05:58:58.990 Timeout detected.
. 2012-09-23 05:58:58.990 Copying files to remote side failed.
. 2012-09-23 05:58:58.991 Connection was lost, asking what to do.
. 2012-09-23 05:58:58.991 Asking user:
. 2012-09-23 05:58:58.991 Lost connection. ("Error retrieving server address","Timeout detected.","Copying files to remote side failed.","Entering Passive Mode (111,90,133,160,154,254)")
< 2012-09-23 05:58:58.991 Script: Lost connection.
< 2012-09-23 05:58:58.991 Script: Error retrieving server address
< 2012-09-23 05:58:58.991 Timeout detected.
< 2012-09-23 05:58:58.991 Copying files to remote side failed.
That logfile loops like that forever.
Please help? Thanks
Are you able to connect using an older version WinSCP or using any other FTP client? Can you post a log file showing that?
