Topic "Disable popup during "Keep remote directory up to date"?"
srynoname
I am using the "Keep remote directory up to date", when a local file changes, then the transfer status is shown as popup. Is it possible to disable this popup? I fear it will steal focus while typing in my favorite IDE and then I will kill the transfer. Also I find it irritating for short transfers, looks like my screen flickers Wink But the functionality itself works great Smile
No you cannot disable it.
But it should not steal a focus. Does it?
srynoname
It popped up so short in my case, I jsut assumed it would steal focus, didn't really test it.
Anyway, I meanwhile used teh great scripting part of winscp and in that case there simply isn't any popup Wink
